Question about Home
Our garbage disposal is leaking between the black rubber gasket and the stainless collar
  • 20 Answers
You must first turn off the power to the disposal ( it could be a wall switch or a circuit breaker) then disconnect the 1inch pvc 90 from the disposal ( its usually black or grey and it's connected to the trap, you should then grip the disposal and twist it to your left because you are facing it. the disposal will then release from the collar check the rubber gasket for any damage or debris you either spin the the disposal back on useing a hammer to lightly tap the metal ring on the collar tighter, if it still leaks remove again and go to home depot and buy a new collar be sure to put everything back together and turn back on power when complete
Posted on Jul 13, 2009
How to replace gasket on garbage disposal
First unplug the disposal from the electrical outlet. Do not just shut the switch to the off position.
You will need to drain the water sitting in the trap so place a container under the trap to catch the water.
Loosen the collar on the disposal ( use a small hammer and screwdriver)
Remove the old gasket on the top of the disposal and replace with the new gasket.
Place a little plumber's silicon on the gasket and reinstall the disposal. ( it might be a little difficult due to the new gasket)
Check for leaks and then plug the disposal back into the outlet
Sep 05, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Need drain elbow for kitchenaid disposal KWS200
Parts are available at many sources
Copy following link to repair parts, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
Jun 01, 2012 | KitchenAid Batch Feed Garbage Disposal...
I have a badger 9 garbage disposal unit, and it leaks after installing from the discharge outlet at the top of the discharge tube under the side flange. I replaced a badger 1 and I used the old gasket as...
Location of leak is not known for sure.
Sounds like leak is where tubular drain pipe connects to side of disposal?
If leak is where disposal connects to sink, typically this connection is sealed using plumbers putty.
Open following link for disposal instructions:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
1) If leak is at rubber gasket for tailpiece connection on side of disposal:
I don't know if your local home depot sells gaskets. Probably not sold separately.
2) Go to home depot and take rubber gasket out of a new garbage disposal box.
3) Or buy new disposal with a gasket, use the gasket and return disposal saying that part was missing..
4) To seal old gasket, use rectoseal white pipe joint compound.
Cover the gasket with rectoseal and then assemble parts.
Open following link above for photo of rectoseal.
I always use rectoseal on tubular drain connections for 100% seal first time every time.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The garbage disposal has a slow drip from the bottom, can this be fixed?
If the garbage disposal is rusted out, then it can't be fixed.
My first instinct is to check other sources of leaking water first.
Maybe you have checked, and the following information is not necessary.
Here's some things to do:
1) Fill the sink without letting any water down into the disposal.
Let the water stand in the sink for a while.
Do you see any water dripping?
If you see water, then that tells you the putty seal at the sink strainer is leaking.
Pull out disposal, remove old putty and replace with ample amount of plumber's putty.
2) Next suspect is where the tailpiece connects to side of disposal.
The tailpiece lets the water flow out of disposal
The tailpiece is usually sealed with a rubber gasket
This rubber gasket can leak
Take it apart. Is the rubber part wet on the outside?
You might be able to buy another rubber gasket... but not likely ...
Good news: you can also seal up this kind of gasket using Rectoseal
Rectoseal is a brand name for a gooey pipe joint compound.
I like it because it's so gooey, and you smear in on with a bush that comes with the can.
Cover the outside of rubber gasket with plenty of rectoseal and then reassemble and see if leak continues.
Use Rectoseal on the washers when putting together any tubular drain pipe under the sink
3) Last suspect is the rubber hose that feeds into the garbage disposal from the dishwasher.
Does your garbage disposal leak when the dishwasher is running?
Try running dishwasher without putting any water down the sink
The rubber dishwasher hose connects to disposal with a clamp.
4) If the water leak is small, I use klenex tissue as a tester.
Tissue shows the smallest amount of water
Put the tissue on a damp area and it shows on the tissue
Start at the top of disposal and work your way down until you find the origin of the water.
Hope we saved you a dollar.
Oct 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 is leaking and i am wondering if the black gasket is replaceable
Yes. it is not hard either...
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water drippinp from the bottom of badger 5
Check all of your seals. Wipe your hand all the way around your disposal to check for moisture running down. Pay close attention to the areas where there are seals, like the top where the main gasket is located and the side where your drain connects there are rubber gaskets that can begin to leak. Also check where the dishwasher drain connects if applicable. If all gasketed areas are ruled out than unit itself may be leaking and need to be replaced. I hope this helps.
May 26, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Home Logo
88 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
