Question about Yamaha HTR-6030 Receiver
Front Speakers stopped working
I have had this Surround Sound System for about 6 months and love the sound. Last night I went to turn it off and pushed a "wrong button" and now the front speakers no longer work. The back, center and sub-woofer speakers are fine. I know it's a matter of just putting it back the way it was but I have been trying for quite awhile now and starting to pull out my hair....HELLP!!
  • 111 Answers
Turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Posted on Nov 16, 2007
  • Trinity Sabre
    Trinity Sabre Nov 16, 2007
    also check to make sure the mute is not active, in some cases this mutes only the front speakers... don't ask me why, i have no idea, but i have seen it happen on two of these systems in the past..
    another thing to check is the amp buttn, press it and check the settings of your front l and front r.
    in sound field, check the settings for stereo and for enhancer, make sure they are set to 5 channel.
    also, if all else fails, press the "straight button" and make sure you have straight mode (raw mode) deactivated or activated depending on your preference..
    make sure to check your input source and input jack source
    under speaker settings make sure "SUR.LR" is not set to none
    this is pretty much everything that should or could be causing your problem, at least everythingi can think of right now
    hope it helps,
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ... > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from
Dec 12, 2015 | Audio Players & Recorders
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
Sound quits after game loads.
are you using original xbox games or 360 games
Dec 16, 2007 | Microsoft Xbox 360 Console
Yamaha Surround Sound HRT-6030
maybe you select the Fader mode.. you simple select the fader balance to center then you hear the sounds coming out to the front fader mode.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
Surround Not Working on TV
well for one thing .. on cable it has to be in surround sound.5.1 or 6.1 for it to true surround.your dvd and cd will be fine .. if you just want to have sound coming out of all speakers you have to adjust your sound settings but it will not be surround sound though
Nov 24, 2006 | Sony DAV-DX250 System
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Yamaha HTR-6030 Receiver Logo
370 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
