Carrier A/C making buzzer noise every 6 minutes.
The air conditioning portion of my day & night HVAC system (model 565BJX030000AAAA) is making a 4-5 second buzzer noise every 6 minutes. It sounds just like my dryer at the end of the cycle. It's 20 years old. What's going bad on it?
    Champion:
  • 233 Answers
Probably the contactor, they have a coil that sometimes buzzes, after the contacts become pitted and no loger pull together like they are supposed to. It could also be a voltage problem from the transformer that is causing it, but I would bet on the contactor. Get it fixed quickly as a voltage drop across the contactor can be the demise of you compressor!
Posted on Jul 14, 2009
Needing information on removing a heater core from a 2012 Chrysler 200
how to? that it the full steps, out and in,,>????
there is lots of information on this....
not in warranty? huh?
and how could IT be bad so soon?? no way/ ,huh?
why not post the symptoms and not guess. the below HORROR
posted to show 2 days lost work (life)
buy the FSM and read the HVAC chapter. every word
or alldata.com , same deal. look, read and decide,
oops I cant to this.....?
parcial excerpts. to prove case.
quote:
The HVAC housing assembly must be removed from vehicle for service of the heater core.
housing out: 101:
Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in an accidental airbag deployment and possible serious or fatal injury.
WARNING
Refer to the applicable Warnings and Cautions for this system before performing the following operation and . Failure to follow these instructions may result in possible serious or fatal injury.
NOTE
The HVAC housing must be removed from the vehicle and disassembled for service of the heater core, A/C evaporator, air intake housing and the mode-air and blend-air doors.
NOTE
LHD model shown in illustrations. RHD model similar.
Heat Shield - Unified Line 08 JC
Disconnect and isolate the negative battery cable.
Recover the refrigerant from the refrigerant system (Refer to Heating and Air Conditioning/Plumbing - Standard Procedure).
Partially drain the engine cooling system (Refer to Cooling - Standard Procedure).
Remove the top nut (2) that secures the heat shield (3) to the stud (1) located on the dash panel.
NOTE
Two slots are provided at the bottom of the heat shield to aid in heat shield removal. Complete removal of the two bottom heat shield retaining nuts is not required.
Reach behind the engine and remove the two bottom nuts the that secure the heat shield to the studs located on the dash panel and remove the heat shield. Rotate and tilt the heat shield as required.
(capture the FREON as required by USA LAWS, Illegal for DIY person to do. so...)
Unified Liquid and Suction Line to Evaporator 08 JS
Remove the bolt (1) that secures the A/C liquid and suction line assembly (2) to the A/C evaporator (3).
Disconnect the A/C liquid and suction line assembly from the A/C evaporator and remove and discard the dual-plane seals.
Install plugs in, or tape over the opened refrigerant line fittings and the evaporator ports.
Disconnect the heater hoses (4) from the heater core tubes. Install plugs in, or tape over the opened heater core tubes to prevent coolant spillage during housing removal.
HVAC Housing to Dash Panel Nut
NOTE
Make sure to remove the five bolts that secure the HVAC housing to the instrument panel support prior to removing the instrument panel from the vehicle.
Remove the instrument panel (Refer to Body/Instrument Panel/PANEL, Instrument - Removal).
Remove the rear floor ducts (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
Remove the condensation drain tube (Refer to Heating and Air Conditioning/Plumbing/TUBE, Condensation Drain - Removal).
Remove the nut (1) that secures the passenger side of the HVAC housing (2) to the dash panel (3).
NOTE
Use care to ensure that the interior is covered in case of loss of residual fluids from the heater and evaporator cores.
Pull the HVAC housing rearward and remove the HVAC housing assembly from the passenger compartment.
at the least, and for sure , things will break, as you work.
get lost, or not figure out how to put it ALL BACK
Remove the HVAC housing assembly and place it on a workbench (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal).
Remove the left side front floor duct (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
NOTE
If the foam seal for the flange is deformed or damaged, it must be replaced.
Remove the foam seal (1) from the flange (2) located on the front of the HVAC housing (7).
Remove the screw (8) that secures the flange to the front of the HVAC housing and remove the flange.
Remove the screws (3) that secure the heater core tube retaining brackets (6) to the side of the air distribution housing (4).
On RHD models, remove the air distribution housing from the HVAC housing (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal)
Carefully pull the heater core (5) out of the driver side of the air distribution housing.
end excerpt.
May 13, 2014 | Cars & Trucks
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
What is hvac
Hi, Hvac that i know is (Heating, Ventilating, and Air Conditioning) refers to technology of indoor or automotive environmental comfort. HVAC system design is a major subdiscipline of mechanical engineering, based on the principles of thermodynamics, fluid mechanics, and heat transfer. Refrigeration is sometimes added to the field's abbreviation as HVAC&R or HVACR, or ventilating is dropped as in HACR (such as the designation of HACR-rated circuit breakers).
HVAC is important in the design of medium to large industrial and office buildings such as skyscrapers and in marine environments such as aquariums, where safe and healthy building conditions are regulated with temperature and humidity, as well as "fresh air" from outdoors.
Heating, ventilating, and air conditioning is based on inventions and discoveries made by Nikolay Lvov, Michael Faraday, Willis Carrier, Reuben Trane, James Joule, William Rankine, Sadi Carnot, and many others.
The invention of the components of HVAC systems went hand-in-hand with the industrial revolution, and new methods of modernization, higher efficiency, and system control are constantly introduced by companies and inventors all over the world. The three central functions of heating, ventilating, and air-conditioning are interrelated, providing thermal comfort, acceptable indoor air quality, within reasonable installation, operation, and maintenance costs. HVAC systems can provide ventilation, reduce air infiltration, and maintain pressure relationships between spaces. How air is delivered to, and removed from spaces is known as room air distribution.[1]
In modern buildings the design, installation, and control systems of these functions are integrated into one or more HVAC systems. For very small buildings, contractors normally "size" and select HVAC systems and equipment. For larger buildings, building services designers and engineers, such as mechanical, architectural, or building services engineers analyze, design, and specify the HVAC systems, and specialty mechanical contractors build and commission them. Building permits and code-compliance inspections of the installations are normally required for all sizes of buildings.[citation needed]
The HVAC industry is a worldwide enterprise, with career opportunities including operation and maintenance, system design and construction, equipment manufacturing and sales, and in education and research. The HVAC industry had been historically regulated by the manufacturers of HVAC equipment, but Regulating and Standards organizations such as HARDI, ASHRAE, SMACNA, ACCA, Uniform Mechanical Code, International Mechanical Code, and AMCA have been established to support the industry and encourage high standards and achievement.
Hope is the one your talking about.
Fill free to pass your comment...
Feb 14, 2011 | Cell Phones
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Buzzer noise from carrier A/C condencing unit.
Sounds like the contactor is bad.It has a magnate that pulls in with a call for cooling,It will buzz like crazy sometimes.
Jul 13, 2009 | Carrier Heating & Cooling
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Cools only at night
Possibly low on gas . Take Thermometer and check the outgoing air. Should be close to 45 degrees If not low on gas. Rusty
May 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
(HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
247 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
