Question about Cobra 29 LTD CB Radio
Do i need new coax for a ball mount - Cobra 29 LTD CB Radio
  • 24 Answers
Yes you can buy allreddy made up at ratshak 50 ohm rg58 for 20 foot run or rg8 for long runs of 20 feet or more
Posted on Jul 14, 2009
Help...Extremely high swrs. Galaxy dx 44v twin tdin Wilson 2000 antenna's, custom new rg59 coax. Mounted on a 99 Kenworth W900L. Swr is near set mark. Good continuity, radio just back from shop for peak...
Measure out your coax in 3ft intervals. Like if you need 7ft use a 9ft length of coax. Also make sure your mirrors are grounded use a external swr meter as well, the internal swr on the galaxy could be off. .
Nov 13, 2014 | Radio Communications
New galaxy dx98vhp, new coax, new wilson5000, new
check that there is a ground connection at the antenna, and that the antenna is not near anything conductive. If your swr is 1.8:1 or lower, your good to go
Sep 07, 2014 | Radio Communications
What antenna
If you cannot use a magnet mount antenna on the roof then a fiberglass antenna (top loaded) about 4 ft. tall mounted behind the cab on the bed rail.You can usually run the coax thru a rain drain hole in one corner of the bed. The antenna should be tall enough to where the top third of the antenna is above the roof. The taller the ant.is the better the SWR will tune.
Jan 20, 2014 | Uniden PRO520XL 40-Channels Base CB Radio
Added new antenna and now im failing rf output and antenna radio test?18ft coax and a 48in ant.
First thing is to be sure the mount is not shorted in any way--and also to make sure that where it is mounted it is actually connected to ground--many newer vehicles have insulators so a bumper even if metal has no ground to work off of.
No ground, open or short in coax, open or short in mounting bracket all can cause no swr or high swr.
May 01, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
-wilson antenna installation diagrams for, Wilson Trucker2000 - display pictures of exactly, how antennas appear when being attached with coax cable, using stud mount between coax & antenna mount... -...
I have a wilson 5000 mirror mount. I mount it on the drivers side mirror on the upper cross arm that goes to the mirror. It is mounted on this arm with a bracket and a so 239 connector so I can undo it if I have to ,leaving the antenna connected.I can change coax and not have to worry about undoing the antenna. Remember one thing. The antenna has to be checked for SWR.each time you move it to a different spot or to a different truck.
Oct 11, 2011 | Cobra 29 LTD CB Radio
How do you replace ball joints
Removing the Ball Joint Step 1 Loosen the lug nuts on the front wheel assembly with the ball joint you need to replace. Do not remove the lug nuts.
Step 2 Set the transmission in neutral (manual) or park (automatic) and raise the wheel off the ground using a floor jack. Then support the car on a jack stand.
Step 3 Chock the rear wheels and apply the parking brake.
Step 4 Remove the wheel lugs and the wheel assembly.
Step 5 Remove the mounting nut and dished washer that secure the stabilizer bar to the control arm. Use a wrench or ratchet and socket.
Step 6 Unscrew and remove the mounting bolt and nut holding the inner side of the control arm to the car's body. This will relieve the tension on the stabilizer bar. Use a wrench to hold the mounting bolt as you unscrew the nut with a wrench or ratchet and socket.
Step 7 Unscrew the bolt on the steering knuckle that holds the control-arm ball joint to the knuckle. Use a wrench or ratchet and socket.
Step 8 Spread the steering knuckle joint that holds the control-arm ball joint to the knuckle. Use a large screwdriver or pry bar. Then separate the ball joint from the steering knuckle.
Step 9 Pull the control arm from the stabilizer bar.
Step 10 Remove the stabilizer bar spacer from the control arm and keep it in a secure place. You will need to use it on the new control-arm ball joint assembly.
Installing the Ball Joint Step 1 Insert the new control-arm ball joint stud into the steering knuckle joint. As you look through the mounting bolt hole on the steering knuckle, align the notch on the ball joint stud with the hole. Insert a new ball joint mounting bolt and start a new nut on the bolt. Tighten the nut.
Step 2 Mount the stabilizer bar spacer in the control arm, then insert the stud bolt at the end of the stabilizer bar into the control arm mounting hole and spacer.
Step 3 Set the other end of the control arm in its mounting position and insert the mounting bolt. Then start the mounting nut on the bolt by hand.
Step 4 Hold the head of the mounting bolt that secures the control arm to the car's body using a wrench, then tighten the nut.
Step 5 Secure the stabilizer bar to the control arm with the dished washer and mounting nut. Tighten the nut.
Step 6 Install the wheel assembly and lugs. Tighten the lugs with the lug wrench just enough to hold the wheel assembly firmly in place.
Step 7 Lower the vehicle and finish tightening the wheel lugs.
Step 8
Remove the chocks from the rear wheels.
Aug 08, 2010 | 1998 Ford Escort
Can't recieve any or little transmissions
You have to match your antenna to your truck. You have to make sure the mount or antenna has a good ground, now if you grab the bottom of your antenna bracket around the stud does this change the noise in your truck. If so then you need to run a ground if not you probably don't have a ground problem, you grabbing it is giving it a ground you can ground it by self tapping screws in the tool box into side of truck. Or if its not a ground problem try another antenna shorter or taller to see if that works and make sure you have at least 18 ft of coax and good coax at that.
May 31, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I purchased a new 959 and would like to know what the best anteana and coaxe cable for this radio is. I will be using it in my 2007 volvo tractor, I'm a line driver in need of the best use I can get from...
coax---18 ft is recommened, all i sell is double sheilded, but as long as its good coax it should work fine...antenna thats a hard one because you have to match the to your tractor..meaning you have to get it tall enough to get to the top of your tractor...make sure you have a good ground..if you're mounting the mount on top of paint either use self tappin screws or scratch off the paint under the mount. hope this was helpful some things are easier to explain over the phone...if you need anymore help just let me know.
Jan 12, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Mar 26, 2009 | Uniden Radio Communications
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
37 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
