Question about Texas Instruments TI-84 Plus Calculator
My TI-84 Silver is in a strange mode
My TI-84 Silver is in a mode I don't know how to get it out of. At the bottom of the Graph Screen there are 3 boxes (Shades, Poi-Trace,?). Also Window begins with Shade Res instead om Xmin. And I don't know if this is connected or a different issue, but when I do a LinReg it does not have r or r squared.
If you want to get that Shades, Poi-Trace,? out of it, you have press you apps button. Then you go to 7: Inequalz and pres 2 for quit Inequalz.
Bye
Posted on Jul 18, 2009
How do i graph an equation on a ti-84 plus silver edition calculator?
1. To graph a function, Press [Y=] to enter the function editor.
2. Type in a legitimate function.
3. Press ENTER to validate the function.
4. Press the GRAPH key to draw the graph.
5. Play with the window dimensions or use the ZOOM feature
to see more of the graph (or less).
Try your settings by drawing the function y= x
If you have problem with Invalid Dimension or other errors, turn the
Statistical Plots OFF.
To do so, press [SHIFT] [Y=] to open the Stat Plots.
Type in the number to the left of the Option PlotsOff. Then press ENTER.
Sep 20, 2011 | Texas Instruments TI-84 Plus Silver...
Buttons on my TI- 84 Plus Silver Edition are not working. I can turn on the device but the buttons don't seem to work. I can't graph at all, or do anything.
Hi
if you can turn on and then click on the on button and this is the only ket that works then its an hardware problem and it can be fixed
let me know if you want to fix
ecrdn@yahoo.com
Jack
Jun 27, 2011 | Texas Instruments TI-84 Plus Silver...
There's a blank bar that runs horizontal in the middle of my TI-84 plus that's about 16 pixels wide(high?). It's the same color as when the device is turned off. I've tried a memory reset and no results....
SPLIT SCREEN.
It sounds as if you might have split screen mode on. I've got a TI-83 as well as a TI-89 Titanium, both offer a split screen mode. The latter allows for choosing which applications are displayed on each half screen. I am presuming that you may have accidentally put your TI-84 in this mode.
So, if it is a split screen deal then all you have to do is go to the mode screen, find the option for switching from split screen to full screen, and switch it back to full.
I hope that helps. Give us your results!
Adios
Mar 11, 2011 | Texas Instruments TI-84 Plus Silver...
I used to have the normal Ti-84 Plus, but my sister has it now, and I bought the Ti-84 Plus Silver Edition, but it has a completely different system. For instance it doesn't write the equation on a few...
If you don't have version 2.53MP of the operating system on the TI-84 Plus Silver Edition, you can download it from
http://education.ti.com/educationportal/sites/US/productDetail/us_os_84plus.html
You can check the version of the operating system by pressing 2ND [MEM] 1. The OS version number is on the second line.
Once you're running OS 2.53MP, press MODE to enter the mode editor. Press down-arrow repeatedly to get to the second page. On the top line, highlight MATHPRINT. Press ENTER to select it, then press 2ND [QUIT] to exit the mode editor.
Dec 26, 2010 | Texas Instruments TI-84 Plus Calculator
How do I send my graph from my 84 plus silver edition to my computer?
  1. Install the TI Connect software on the computer.
  2. Connect the calculator to the computer using the Silver Link cable or the USB direct cable.
  3. Run the TI Connect software and let it recognize the Calculator.
  4. Once this is done, create the graph on the calculator, and click the screen capture button in TI Connect.
  5. Save image in jpeg format.
  6. Send it to the printer to print or insert it in a text document which you then print.
Dec 15, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 Silver - Screen only works at certain places.
It may be a hardware problem, but there is apossibility that you have activated the Split screen feature.
[MODE] opens a configuration screen. At the bottom, (the last line) has [Full] [Horiz] and [G-T]. Full means screen is complete; Horiz means screen is split down the middle, horizontally in two; G-T mesn screen is split vertically in two; To the lesft is the Graphic screen, to the right is the table of values pertaining to the graph.
[MODE] DownArrow to last line, make sure that [Full] is highlighted.
Hope it helps.
Sep 04, 2009 | Texas Instruments TI-84 Plus Silver...
Ti-84 plus silver edition will not graph
try going into the memory men (2ND - +), and selecting option 2.  Delete some stuff you know you don't need.  If the problem persists, 2ND - +, this time option 7.  Reset the defaults.  You won't lose anything, it will just reset the settings that may be causing this issue.
Jan 25, 2009 | Texas Instruments TI-84 Plus Silver...
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
4,155 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
