This is a tricky one you could try tyaking the top of the radio off and see if you can help slide it out. Another trick is to get a thin stiff piece of cardboard like the back of a writing tablet cut a strip apx. 2" wide and 6" long. Take a piece of ducktape and with the sticky side up insert under the disc hit eject and see if that will coax it out.
What kind of problem? Not turning on, not fitting, clipping? Gotta give details if you need help, there are about a million reasons there would be problems!
i tried their registration site which was blocked by my browser but you can call them at the number below and have them help you register it. the number is for Pioneer
I am having the exact same problem and I do not know what to do about it. I will probably call up pioneer and ask them about it.
If you already got this problem fixed then please tell me how to go about this issue
Thanks
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way 2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously. 3-Release the reset button. 4-Release the dvd eject button next. The display will read “press reset” 5-Push the joystick up two times. 6-Push the joystick down twice. 7-Press the joystick in. 8-The service menu will appear after a short pause. You can navigate the service menu using the joystick. 9-Chose the first menu option and press in on the joystick. 10-Trace the screen with a stylus. 11-"P.ADJ" is the back button 12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
