Add additional mics on the vocopro gigman all in one system
Hello, I would like to add two addtional mics fora total of four on my karaoke machine & I am not sure how to do so. My machine has 2 XLR mic inputs and 2 1/4 in jack mic inputs, however the manual states that both cannot be used simultaneously. Is it safe to simply purchase a spliter for each 1/4 inch mic jack , thus having 2 mics per 1/4 in micinput? Can you offer nay other solutions.
  • 34 Answers
Putting spliiters on the input of a Mic priamp to connect to Mics to one pre is a bad idea. There are lots of techy reasons why, but the short version is "Don't Do it"
So how to solve your problem..
If you have a spare Line input you could buy a cheap external mixer, which will take the microphones and provide an appropriate level signal to your machine.
Something like this ought to do it..
If you have no line inputs, then you can use the output of the mixer into a DI Box to match the levels and use your exisiting Mic ins.
Posted on Nov 16, 2007
  • ROb B Nov 16, 2007
    If my solution was helpful, please vote for me!
Can i replace the dvd player in my karaoke machine myself?
perhaps you could if you knew the make and model of the player and where to buy just that .. a phone call to a computer repair shop might answer what you wish to know
Dec 15, 2015 | KARAOKE Vocopro Champion-RV Player Machine...
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
I need a channel slider for a vocopro mixer KJ7000
various types are avail at mouser and digi-key .com. google them -check their catalogue and search under potentiometer.verify value,physical dimension and shaft length.
Mar 03, 2010 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
I need a schematic for the vocopro entertaner model no HKH000011
You might try emailing the service centers listed here and see if you can get lucky:
Jan 23, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
I have a Memorex Karaoke machine, Press power button, screen comes on but it will not play a disc nor cassette. There is a small light beside the power button but it does not come on either. What could be...
Had same problem opened up back found blown fuse replaced and still blows.
Unhooked power source from were fuse was blown and fuse dose not blow seems to be something in that big board above it.I'm realy not into repairing of electronic boards. There is a lot or stuff going on inside there.
Just thought I would share my experience.
Good luck
Oct 20, 2009 | Memorex Karaoke System MKS5620RFB
Wantind to add mics to my karaoke machine-Vocopro GiGMan karaoke system
I'd get a small mixer, then run mics into that, mix em down to 2 channels then send em to the karaoke machine, that way you have control in mixing multiple mics down to 2 channels, I wouldn't bother with 1/4 " mini plug mics or splitters personally.
A D.I. box ( direct injection ) takes an instrument or line level signal through a step down transformer and it comes out the other end as a mic level signal, the purposes of it are for running an electric instrument into it wich is split into 2, one for going to the input stage of a mic pre, the other can go back out to an instrument amplifier, this way you can run a direct signal into the console via " direct injection " into the mic pre as a mic level signal and also can run it to your instrument amplifier in order to be able to also mic the speaker cabinet acoustically at the same time, there are many benefits to this, for instance in live shows if the speaker cabinet or mic fails then you still have the direct signal, also since the direct signal tends to be punchier and clearer, cleaner, than an acoustically mic'd signal, they can both be mixed together at the console to give a a desired blend of each signal. Since there is a small delay between the direct signal and the acoustically mic'd signal because of distance of the mic from the soundsource delaying the direct signal a bit may be desired. D.I. boxes are only for instruments, they are superflous for vocals, the quality of the D.I. box does matter and active D.I.'s are the way to go, passives are as they are in speaker crossovers, less than desirable quality. There are also many tube D.I. boxes, generally a D.I. box isn't necessary for running an instrument into a consoles mic pre because most consoles take line level inputs as well, and there are other ways for getting a line level signal into a console by bypassing the mic pres anyways, If you have quality mic pres it's good to use them for the initial gain stage though as opposed to boosting instrument level to line level using a crappier preamp, for instance running an electric instrument input through an effects pedal will raise the instrument level to line level but of course an expensive mic pre will do a better job of it than an effects pedal will, since the first gain stage is paramount to quality......................
Nov 17, 2007 | Audio Players & Recorders
Microphone Line Jack Trouble
it sounds like theres a switch on your mixer to lower the music when the mics switched on, called talkover.when you switch the mic off the music will return to normal levels. find the switch on the mixer and set it to 'on' not talk
Dec 04, 2006 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
144 people viewed this question
