Question about Car Audio & Video
2 CD s in disc player
My son forced a second cd into player. When eject button is pushed a RRRRRR noise is made, but cds willnot come out. AAAAHHHH It's a factory stereo from Ford
    Problem Solver:
  • 15 Answers
Is there a small hole beneath the bay?
If so insert a paperclip in it and press lightly to open the drive's drawer.
Posted on Jul 13, 2009
Help getting CD from 2005 Nissan Pathfinder CD player
Press and hold the Eject button for up to two or three minutes to attempt to force the disc out.
Aug 12, 2014 | 2005 Nissan Pathfinder
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
2006 Grand Vitara 6-Changer CD Player will not eject cds. 'Push Eject' error comes on.
this is a longshot, try unplugging it, wait about 30 seconds and plug it back in.
Sep 17, 2012 | 2006 Suzuki Grand Vitara
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Oct 23, 2009 | 2002 Honda Accord
We just bought a new cd and it's stuck in the car stereo
If you like you can read throuh the manual for further help if this fails,
at this address :
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf
However the units have a forcible eject mode, im raking my brain for it but i think 90%  sure its as follows...
Try pressing and holding eject and the power button at the same time for about three to five seconds, the machine shoudl buzz louder then normal an do a full eject cycle for about 2 seconds,
If worse comes to worse you can take off the outer casing  four screws (if not under warranty) and carefully lift the disc slightly and slide it out. Take care to to force anything as you can damage/scratch the unit.
Another option is that you ring the Kenwwod customer service number and ask how them what the button press combination is for forcibly ejecting cds from the unit. you may need to ask for someone in repairs there to get a knowlegable answer,
Hope this helps
Cheers
STeve
Feb 15, 2009 | Kenwood KDC-122 CD Player
2008 Durango Limited
The eject button is the load button on our 2005, maybe the same for you. Just hold it in for a few seconds and it should spit out your cd. You should be able to lightly put the cd up to the insert space and it should take your cd. If your cd player holds multiple cds then perhaps there are some in there that have not been ejected. Hope this works for you.
Oct 27, 2008 | JVC KD-AVX1 Car DVD Player
Stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
CD stuck in ps3 horrible noise cant get out HELP!!!
I had the same symptoms. The reason to my problem was that my 2 year old has pushed *three* disks into the console. I got them out through the following, admittedly pretty weird, approach: I hit the eject button, while gently prodding with another disk into the slot (at a slight upward angle). I could feel the disks inside the console rotating or vibrating as I was *gently* touching them with the fourth disk and hitting eject repeatedly. Somehow, the gentle prodding made one of the disk come out a bit, so I could pull it out easily. (I was pretty surprised when a second disk came out, and then a third.)
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
