Question about HP Photosmart C7280 Laser Printer
How to remove a paper jam from the vivera paper tray
  • 296 Answers
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Posted on Jul 13, 2009
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
241 paper jam
Check the paper tray guides, check the the paper feed roller (remove the tray and look up in the printer) it is possibly worn and needs replacing, you can try to clean it (hand soap is as good as anything)
Apr 15, 2009 | Lexmark C510 Laser Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
HP Photosmart C7280 Laser Printer Logo
476 people viewed this question
Seeker5211
Seeker5211
