It shows 02 and f
My washer shows "02" then "f" when its almost at the end of the cycle. other times it shows the word "sud". whats wrong?
  • 5,911 Answers
I'm assuming this is either a Whirlpool Duet or Kenmore Elite front loader? Since you posted no brand name or model number, its hard to determine, but I do know these error codes are usually for these brand washers.
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The "SUD" error can commonly occur with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Posted on Jul 13, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 13, 2009
    http://www.fixya.com/support/r615268-f02...
What does it mean when SD is showing on the display
The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
Jan 19, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer showing error code SUD
any f35? or is it just sud?
is it green?
if it is just sud and happens towards the end of the cycle take your kick panel off....3...7 millimeter screws or t15 torques whatever you have will work.
twist off the pump catch see what's inside...if there is socks and debrie you fixed your problem.
if it happens at the beginning you have a bad pressure switch usually happens on the steam washers....what color is it?
May 04, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My washer stops about half-way through the cycle and displays an "02 F" message. I have to pause, then restart in order to complete the cycle. It sometimes does this twice per cycle. Any ideas what could...
This is the problem below.
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
www.appliancehelponline.com
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
display.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
or kinked.
Have "sud" code and"f 02" code
I don't have a solution but I feel your pain.
I had an F02 error flashing so I got brave and took off the front panel and opened up the drain thing. What a mess! Water everywhere and OMG,the filter was caked with goop, a popsicle stick and a piece of metal.
I still get a Sud error so I am having the Sears guy out in the morning.
Oct 25, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F 02 ERROR
Try cycling the washer a few times without a very small load of clothes and no detergent. I assume that you are and have beenm using only HE type detergent and I suggest you try using about 1/2 to 1/3 the amount called for until your system is purged of any and all remaining detergent in the lines. Here are the manufacturers reccommendations to address your problem..
“SUD” (Suds Routine)
When excessive suds are detected, a suds routine
automatically starts. This routine removes extra suds and
assures proper rinsing of your garments. “SUD” is displayed
during rinsing and at the end of the cycle to inform you that
Suds Routine was activated. Use only HE (High Efficiency)
detergents.
Hope this helps you..
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I used the wrong detergent
ok...run a really small load with no detergent, on rinse cycle only..
do that 3 to 4 times, until that suds message goes away.
Feb 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
232 people viewed this question
Top Washing Machines Experts
