Question about Maytag Dryers
Makes sound, doesn't work - Maytag Dryers
    President:
  • 942 Answers
Hi...
If your dryer is noisy you need to check this following:
  • Level the dryer
  • Check the drum belt
  • Check the drum support rollers
  • Check the idler pulley
  • Check the glides
  • Check drum bearings
  • Check the blower
  • Check the baffles
Good luck !!!
Regards
PCmania
Posted on Jul 13, 2009
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
Jul 17, 2012 | 1999 Plymouth Breeze
My fan doesn't work nor does the motor make a sound.
Need help with a fun like to bypass the which
Sep 24, 2011 | WeatherWorks CH-1640SF Fan
I have numerous proglems. I have a 2000 intrique. The right back signal light blinks very fast, doesn't work in the front. The ac blower works fine but blows warm air.A mechanic , someone my hysband...
Your rear turn signal flashes fast because the front is not working. Most likely you have a burnt out bulb in the front. If your A/C compressor can be turned over by hand and doesn't lock up or make any clanking sounds it's probably alright. The compressor will not run if the system is low on refrigerant. If you're having problems with the A/C and heater controls, that would be the first ting to repair. It doesn't sound at all like any electrical problems.
Jul 20, 2011 | 2000 Oldsmobile Intrigue
My igniter on the cooker doesn't work, it doesn't click or make any sound
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 17, 2011 | Ovens
Very low volume HK 695-01
There are several ways in which you can increase the volume.
First, the most obvious way is to use the volume control attached to the speaker unit itself. If that isn't working, there's also an icon in the lower right-hand portion of the task bar in Windows. Simply click the ^ button, select the icon that looks like a speaker, then drag that up to your desired preference.
If that doesn't work, click on Start, go to Control Panel, click on Sound, then search for your Speakers in the "Playback" tab. First, make sure it's set as your Default Device. There should be a green check mark in it. Double click on those, select Levels, then make sure Play Control is set to maximum.
If that doesn't work, then check the settings on your Sound Card. Make sure the wire going into the back is plugged in properly. You may need to update your sound card drivers. If you aren't sure who the manufacturer of your sound card is, you can find out by going to Start > Control Panel > Device Manager. The Manufacturer will be under Sound, Video and Game Controllers.
Once you have that information, you can go to the Manufacturer's website and update the Drivers. If this doesn't resolve the issue you are experiencing, or if you require more specific / additional information, simply respond to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 03, 2011 | Harman Kardon HK695 Computer Speakers
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
My back speaker doesn´t work,, everything is
It sounds like it's your radio if it's the OEM. To make it somple the factory radio had there separate amp muilt in each chanel so if one speaker went bad the others woudl still play. There is no quick fix other then haveing it replaced or if have it repaired.Good luck and just dubble check all the connections
Apr 08, 2009 | 2004 Dodge Durango
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
