Question about Homelite Mighty Lite Lawn Trimmer
Homelite trimlite UT 20760 string trimmer 2 questions as a result of dislodging some parts while removing casing to reestablish starter pull cord: 1. How to attach throttle cable to metal throttle plate. There are numerous holes that it could fit into -I tried the most logical hole but throttle lever still not working properly. Cannot find a diagram on the web to show how it attaches. 2. Rubber tubing attached to fuel filter inside the gas tank became unattached outside the gas tank. Can wiggle it back into gas tank but is there an access method to inside the gas tank to attach it back to the fuel filter tube?
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Working on greasing up my
Were you greasing the flex drive cable? That is really the only part requiring it unless you have a gear drive on the string head. Attatch the throttle cable onto the throttle plate hole which gives you the least amount of slack with the trigger off. That way, throttle response will be instant.You don't want but a little slack in that cable.
Posted on Jul 20, 2011
Working on greasing up my Homelite UT 20760 grass trimmer. Took the throttle assembly part and having difficulty putting it back together. Can't find any diagrams and which hole to attach to on the...
Jul 19, 2011 | Homelite Mighty Lite Lawn Trimmer
Model ut20760 trimmer engine parts list
Here you go. See page 5 for engine parts. This link has the whole machine.
http://www.odref.com/homelite/string-trimmers/ut-20760-note.PDF
You will need Adobe Reader on your computer to view this parts list.
Apr 19, 2011 | Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
No power
there is a little screen in the muffler these get stopped up some time remove it start engine if this works just clean it and replace it back ..
Sep 09, 2009 | Garden
Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Jun 22, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Need part number s for the entire head assembly of the Homelite Trimlite UT20721" or manual and diagram
Hello daniel_s_kmi:
If I Understand you, you are Looking for the Part Number for the Complete String Head.
If this is Correct, then the Part Number is DA3001A.
>>You can View a Breakdown of this Unit at this Site Addy; http://www.homelite.com/service_support and Select Order Parts. Now Select "Click to Launch Homelite Catalog". Now Enter the Model Numbers (UT-20721) and Click Search. Now Double Click on the Model in the Results Area. Now you can View the Breakdowns for this Unit. Select the "Shaft-Spool and String-Grass Deflector" File. The Complete String Head is # 17 in the Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite Mighty Lite Lawn Trimmer  Logo
1,479 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
