Misfires are typically a result of a few things`:
Bad rocker cover gasket & spark plug seals leaking oil into the spark chamber which fouls plugs. Easy to check, simply remove a spark plug and see if it is dry or covered or damp with oil. second would be faulty wires, change both the plugs and wires. Check all vacuum hoses to see that they are tight, no cracks, leaks etc. There could also be an issue with your throttle body. Is your check engine light on, if so, obtain a scan tool and check for the code that appears.
Check Engine Light and Misfire Due to Ignition Module/Coil ...
repairpal.com > Problems > Chevrolet > Cobalt
Check Engine Light Due to Engine Misfire on Chevrolet Cobalt .... 2007 Chevrolet CobaltVisitor ... The coil pack was bad and was making the cylinders misfire.
