Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
A white screen that says set top diagnostics is on the screen
How do I get it off the screen
    Genius:
  • 1,139 Answers
Hello pwon28,
This means that your set top box has been put into diagnostic mode and is showing on the TV. Power down your cable/satellite Set Top Box and then power it back on. This should clear up this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 13, 2009
White screen
disconnect the external screen.
Restart the computer HOLD the keys CTRL+f12 or f12 depend or you model or mark, and go to restore factory default and try again.
If the problem persist RUN your software diagnostic coming with your computer or download from your manafacturer supplier
for easy diagnostic and fix it.
God bless you
Jul 10, 2013 | Toshiba Satellite M305-S4826 Laptop
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Half screen , left normal but only half usable. right was black now blue and white, Dell inspirson 1501.granddaughters so would love to fix
Reseat the video cable connection under the keyboard. If no change, press the Fn Key while Pressing power button, this will start a PSA diagnostics, there will be 2 sets of color bars appear and a Yes or No at the end of 2nd color bar, press N to start the LCD diagnostic. If the LCD is still 1/2 and 1/2 in the LCD diagnostic, you need an LCD. If the issue doesn't appear in the diagnostic, then replace the motherboard.
Jun 14, 2009 | Dell Inspiron 9100 Notebook
Base rw Model dw-2200 dvd player?
ok first connect the red/white/yellow output of the dvd to the top box red/white/yellow input. Get the extra a/v cable then connect to the red/white/yellow output of the top box to red/white/yellow of the tv a/v video input A/V1 or A/V2 and last connect the RF aerial to the top box antenna in.
May 13, 2008 | Televison & Video
IPOD NANO - Starts With White Screen, Stays With White Screen. Can't see Anything.
1 Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
2 Press and hold the Center and Menu buttons for at least 6 seconds, until the
Apple logo appears. this resets the ipod
Mar 16, 2008 | Apple iPod nano
Nintendo Ds Lite White Screen
Try cleaning the game. If you look at it in the light you may find it has some scratches or something. You see my brother has that! Love Tamsin
Mar 15, 2008 | Nintendo DS Lite Console
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
