Popping on acceleration
It could be a problem in the valve train. For a car that old, before putting new parts in, you could buy a compression tester for about $30, and do your own compression test. It should tell you if the engine is good enough internally to warrant proceeding. If compression is low on any cylinders, that problem must be addressed first. If a valve is not sealing and causing the popping, that cylinder will show low compression.
For the test, the engine should be at normal operating temperature. Then pull all the plugs out, connect tester to #1 spark plug hole. Have a helper hold the throttle wide open while cranking the engine over about 5 seconds. Watch the gauge-the first revolution or two will cause the gauge to jump high at first, and successive revolutions during the 5 second span will cause the needle on gauge to climb a little each time. Record or note the compression on #1, then do each cylinder. Try to do the same amount of cranking on each cylinder, and keep the throttle wide open. What you want are compression readings on each cylinder that is well above 100 psi, and all should be close. The lowest reading should be within 75-85% of the highest reading cylinder. Example: say your highest reading is 135 psi. 85% of 135 is 115-so your lowest reading should be at least 115 psi. Some general guidelines: any cylinder with compression below 100 psi is definitely a problem-that cylinder will not have hardly any power output, even if it is firing. Worn piston rings or poor valve sealing is causing compression loss. A newer engine should have compression readings above 150 psi. As the engine wears, compression will drop. In general, for high mileage engines, you would want to see compression in the range of 125-150 psi, the higher the better, but remember, it should be balanced-the lowest should be at least 75% of the highest reading cylinder.
Post back if you have questions-good luck.
