Question about NetGear RangeMax WPN824 Router
Sympatico I have problem connecting router to speedstream modem. Router does recognize pppoE but would not connect, so I am using it as wireless connection point linked to my old wired hawking router for connection.
  • 173 Answers
  1. Start your network in this order:
    1. Turn the modem power off.
    2. Turn the router power off.
    3. Turn the modem power back on. Wait two minutes until the lights are stable.
    4. Turn the router power back on. Wait one minute until the lights are stable.
    5. Turn the computer power back on.
  2. Open an Internet browser, and type If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to
  3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  4. Click OK. This logs you into the router
  5. Click Setup Wizard on the top left corner, Select Yes for the Setup Wizard to detect the type of internet connection and click Next.
  6. The Setup Wizard will detect the type of Internet connection. DSL connections which require a login to connect to the internet will be detected as PPPoE. Click Next
  7. Configure your router with the username and password provided by your ISP and click Apply.
  8. The router will now save these settings. When complete, you can verify whether you are connected to the internet from the Router Status > Maintenance menu.
  9. Verify you have a valid IP address (not-blank / on the Internet Port assigned by your ISP
  10. check if you are able to go online wired..
  11. to setup wireless
  12. Click Wireless Settings under Setup menu.
  13. Under Security Options, Select WEP (Wired Equivalent Privacy)
  14. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  15. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
  16. then check in your w/ls laptop, you would find your w/ls n/w name , try connect to it, enter your key , you would get connected
Posted on Nov 16, 2007
How do I discover or reset the password
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Dec 14, 2011 | Efficient Networks SpeedStream 5200 Modem
I can't get my wireless g broadband router to work with my dsl speedstream 5100 modem i can connect to internet when my ethernet cable goes from my xp pc or my mac osx desktop directly to the dsl...
make sure that there is no IP conflict with the two devices. speedstream and wireless G. if both of them have same IP gateway you have to change the IP either one of them for you to have a connection.
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex:
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
turn on the wireless option in the router...
plug your computer into the router type in
username: admin
Password: public
go to wireless tab
turn it on
Also you have to be in range!
Sep 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Have a dsl modem and want to add a wireless router to the mix
There sould be an icon on the botom right of your scren right click it and say view avalibe wirless networks. Then you would find your network and say conect if it is protected by a WEP password it is on the botom or the side of you router.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
3com wireless router and Sympatico
well you could probley find a better router that the model you have it is probey a older model and probley will not work on some computers.
Jan 03, 2009 | 3Com OfficeConnect Wireless Router
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to » This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
No connection with Inter with dir-625 - connection Poep
If a single computer is connected directly to the speedstream modem(a model number would be an added help), do you need to sign on with your userID and password that was provided to you by Bell Sympatico? if the answer is a yes you may need to setup PPPoE on your router but if your answer is no, then you may need to check the IP address your computer is getting from the modem if it's a private IP(192.168.x.x or 10.10.x.x) that means your speedstream modem is set to PPPoE, check if your router has the similar IP address as your modem, compare the default gateway address your computer is getting when connected directly to the modem and when connected to the router if they have the same segment like 192.168.1.x or 10.0.0.x your required to change the IP address on one of the device, my suggestion is to change it on the router then make sure you connection type is set to obtain IP address automatically(DHCP) or something like that and check if your router will get an IP from the speedstream modem.
Jan 21, 2008 | D-Link DIR-625 (790069292637) Wireless...
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
NetGear RangeMax WPN824 Router Logo
1,057 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
