Filter light is on
My filter light just came on as well. No clue what the problem is.
  • craiggear Jul 13, 2009
    I lost my manual, and the manufacturer does not have a website. Thank you for the peace of mind though, that you think it is just a timed reminder to check the filter. Filter seems o.k.
    Champion:
  • 233 Answers
It is a timed report set up when the stat was first set up, it is a reminder to check your filter because of the amount of on time of the unit, the unit should still operate properly, you just need to change/inspect your filter, you can reset this reminder to go off the instructions are in your manual for your stat or online at the manufactures website
Posted on Jul 13, 2009
How do you determine if your fuel filter or fuel pump needs to b replaced on 2000 Ford Taurus
Best practice to start at the filter if there are any fuel problems Kevin. One batch of bad fuel can ruin a filter, it doesn't have to take 20,000 miles, and if excess water, salt, grit, metal swarf or other stuff is in the fuel the filter is where you are most likely to discover the first clues or positive evidence.
Draining the filter into a clean bowl and examine the contents with a good light, looking carefully into the sediment bowl, remove any gauze prefilters and look through them and so forth are all part of the maintenance programme and the diagnosis process. Shaking or tapping the filter over clean paper can produce more clues or evidence and I routinely carefully open the canister types with a hacksaw in order to look inside.
This also helps to choose where not to buy fuel in the future.
Much of this of course depends on the symptoms experienced but it is pointless proceeding with any testing where the pump still works or tries to work unless the filter and fuel are both known to be good and the lines are known to be free from obstruction.
Excess water in the fuel tank can stop a fuel system dead simply because the prefilter gauze is too fine for water to pass and so in spite of the pump attempting to work it will be starved of fuel. Any case of low or non-existent fuel pressure where the pump seems to be working needs an examination of the contents of the fuel tank. I have taken gallons of water from fuel tanks and of course in cold weather when the water freezes it causes even more difficulties.
Truck drivers lighting small campfires under their trucks used to be a fairly common sight before winter fuel additives and in-fuel heating systems were thought of.
Feb 08, 2015 | Ford Cars & Trucks
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
I just got a Gmail Account. I have no clue how to
Go to "parameters" than select "filters" scroll down to "create a filter"
follow instructions. At the end you have to assign that filter to a new label. That's all
May 14, 2010 | Google Gmail
Honeywell Furnace Air Filter clicking noise after cleaning it
I also have this problem as soon as I pt a new filter in - does anyone have a clue what this problem is?
Apr 09, 2010 | Honeywell (F50F1032) Air Purifier
Shifting Problem
drop pan & filter open filter for clues probably over haul
Aug 25, 2009 | 2001 Pontiac Grand Prix
The vehicle began to run real sluggish and the warnig "failstop failure" came on and a light in the dash in the shape of a wrench?
This indicates that a sensor(could be any of many) has either failed or is providing values outside of the normally expected range. The vehicle computer is substituting estimated values for the actual measurements from this sensor to keep your engined running(failsafe mode).
The problem could be minor or serious. Take it to any parts store and have them pull the codes, these should provide clues as to what the problem is. Most parts stores will do this for free.
Aug 20, 2009 | 2005 Ford Freestyle
I have a dodge neon 2000 and its sputters and hesitates plz help
Any check engine light? If so, read the code(s) with a rented scanner and follow the clues. Could be weak fuel pressure (pump) or plugged fuel filter. It could be other things, but these two are common. Check the air filter also.
Aug 17, 2009 | 2000 Dodge Neon
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
