Question about ASUS Eee 4G Notebook
I need tormat the sistem - ASUS Eee 4G Notebook
  • 453 Answers
Turn off the system. Press Ctrl+F11 or just f11 to start the system restore option. It will restore the system back to its original factory settings.It will wipe the entire data in your system and install the OS automatically.
No CD is required for this process.
Posted on Jul 13, 2009
Volume label
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Oct 21, 2013 | Verbatim Electronics - Others
Need to restore my sony vaio vpcee31fx
You can restore the sistem to a previous time you choose ,or you can Recovery it to the Original Factory State ,you better get an USB drive or some discs before ,and get a backup from all your data,than you launch the recovery tools sistem and you wait for the sistem to reboot,it can be 15 minutes or 1 hour ,but it will be as new.
Feb 10, 2013 | Sony VAIO EE Series Notebook VPCEE31FX/BJ
I have a 1971 SEEBURG MODEL USC2 "Bandshell"
Tormat has been energized by movement over the carpet, someone touching it with a high charge or natural static in the air of a dry house. There is a procedure to deenergize the tormat with a battery. I am searching for the battery size and procedure myself. I will come back if I find out
Jan 11, 2011 | Audio Players & Recorders
E class mercedes 200 1997 abs light on dash board.abs not working
every time that light stays on it means that the ABS sistem is disabled...if theres a problem with the sistem it disables itself for safety...so you need to take the car to have it checked and figure out what is wrong, that light is there to let you know theres a problem and now the sistem is disabled so u need to have it scanned and diagnosed.
hope this helps
Nov 14, 2009 | 1997 Mercedes-Benz E-Class
Seaburg stereo phonograph. the only thing that works is the motor goes back and forth but won't select a record. modol elpc480 dbl22
If you have a manual look at the connections that run up and down over the tormat.
The tormat has connections for the A' side and B' side and acommon rail. These connections get dirty.
The best way to clean the contacts on the Tormat is with a pencil rubber (eraser) and then rub over with a lint free cloth. There are pins that run over the contacs, these are wired with very fine flexable wire that can come unsoldered.
If the above is not the problem then you need to have the control boards tested/repaired.
Regards
Alan Hood
ami-man
UK
Oct 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Air condising charger but no compressor turning on
ARE YOU SURE YOU CHARGE THE SISTEM IF YOU DID HOW YOU DID IT BECAUSE IN ORDER TO CHARGE THE SISTEM COMPRESOR NEEDS TO BE RUNNIG IN ORDER TO CHARGE THE SISTEM
Jul 28, 2009 | 2000 Ford Taurus
4x4 transmition sistem
no its not worth it. you would have to change the trans a nd the front axle to go to electronic. then if something breaks you need diagnostic tools to fix. manual is alot more durable trust me
Jan 25, 2009 | 2002 Jeep Grand Cherokee
Mechanism will not pick up records
Check out the tormat on your jukebox. It runs almost the full length of the mechanism. On the tormat is the A and B side contacts and a ground rail. You will see that on the mechanism is a arm that runs over these contacts on it it has very fine wire links (similar to those on motor brushes) these can become disconnected and may require being resolderd back into place.
Regards
Alan Hood
ami-man
UK
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Seeburg entertainer
When you get your manual (the 1975 Entertainer is the STD2) I would check out the very fine cables that are on arm that runs over the tormat on your jukebox. On the tormat is a series of contacts A and B that are for each of the record selections. The contact can be cleaned with a pencil eraser (rubber) this will clean the contacts up with out any damage.
Regards
Alan Hood
ami-man
UK
Dec 08, 2008 | Wurlitzer Jukebox 1015 One More Time...
Vauxhall vectra 2000
try having the top spring beraing changed
Oct 24, 2008 | 1997 Acura CL
ASUS Eee 4G Notebook Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
