Question about Dometic Rooftop RV Air Conditioner
Have a duo therm ac unit that blows hot air - Dometic Rooftop RV Air Conditioner
  • Mike Butler
    Mike Butler May 11, 2010
    Obviously blower fan working , but no sound of compressor kicking in?
THE REVERSING VALVE MUST REMAIN ENERGIZED ON A DOU THERM A/C IN THE COOL MODE IF A/C HAS HEAT PUMP BUILT INTO IT. IT WILL BLOW HOT AIR IF IT DOESN'T GET ENERGIZED. MAKE SURE VALVE IS GETTING POWER TO IT. TAP IT A FEW TIMES IF IT ISN'T AND SEE IF THAT FREES IT UP. IF THE VALVE IS NOT GETTING POWER CHECK WIRING ALL THE WAY BACK TO PC BOARD. IF WIRING IS GOOD REPLACE BOARD. IF REVERSING VALVE HAS POWER AND TAPPING IT WON'T FIX PROBLEM, REPLACE VALVE. THIS INVOLVES BREAKING INTO THE CLOSED COOLANT SYSTEM AND MUST BE DONE PROFESSIONALLY. GOOD LUCK FINDING A PERSON TO DO THIS. MANY COMPLETE A/C'S GET REPLACED BECAUSE OF THIS PROBLEM.
Posted on Aug 28, 2009
  • 92 Answers
Sounds like the compressor is not kicking in.
Posted on Jul 16, 2009
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Does not blow air through ducting
sounds like duct damage or restriction in duct work.
Sep 02, 2012 | Dometic 457915 Duo Therm Brisk Air...
Rv ac unit blowing warm air not cool air
if fan is on auto and on cool bad cooling unit
Jul 06, 2012 | Dometic Rooftop RV Air Conditioner
Ac is blowing 3 amp 12 volt fuse in control box it is a duo-therm ac unit in an rv model #57915622
Pinched wire going to thermostat, condenser fan froze, or bad compressor
Mar 02, 2011 | Heating & Cooling
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Ac blowing breaker
The unit will draw more current when hot. Check rating of the breaker against the rating recommended by the manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
I have a dometic duo-therm. No air coming through ducts.
Sounds like the ducting have come apart in some areas or blocked in some way. Take the supply grills off and with a shop vacuum try and reach as far as you can.
Mar 18, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
476 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
