Question about KitchenAid 31 in. KGCS105 Gas Cooktop
I have model # KGCT365X KitchenAid gas cooktop and one of the knobs that turns the burner on has split in the spindel area and won't grip enough to turn the burner on. Can one be ordered?
All four of mine did this.I glued it with a good quality super glue (don't get any inside or it won't fit back on)
Then I wrapped it many, many times with fishing string.Glue the end of the string after you cut it.Make sure that it holds.Then using alot of the super glue,spread/smear it all over the string.Its almost like fiberglass.Let it dry up real good over night.The first one I did almost 6 years ago and still holding.It's a lot guicker and easier then it sounds.
Posted on Aug 10, 2010
Oven button will not engage
Remove the knob/button and look inside if it is split it won't grip the shaft and needs replacing.
Apr 15, 2014 | Amana Modern Maid Downdraft Stove With...
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
After cleaning the cooktop surface the "clicking"
I just solved the continuous sparking in my gas burner. I removed the control knobs and the rubber below those knobs. Gave the rubber and the area below it a good clean using kitchen and bath cleaning wipes that I bought from Coles. The key is to remove the water and grease from the rubber and the area below it. Good luck!
Mar 24, 2011 | GE Profile JGP636 Gas Cooktop
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Burner caps
Call a local independent whirlpool dealer. they can order the parts from a supplier, and most do not charge sipping as sears a.k.a. A&E will. And they will usually be less expensive too.
Aug 24, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Kitchen gas 4 burner cooktop
i think all igniter switch are grounded,i request to call expert technician to repair it, or uf u want u open the cooktop to see the igniter swicth at konb control area,clean one by one using thinner,remember switc off the plug first.
Aug 03, 2008 | KitchenAid 31 in. KECS100 Electric Cooktop
KitchenAid 31 in. KGCS105 Gas Cooktop Logo
526 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
