Question about Canon PowerShot A85 Digital Camera
Picture is like smeared paint on wall, pink blue, red
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jul 13, 2009
My camera has pink monito when on. and its copied pictures are also pink. what should i do? ty
Posted on Jul 28, 2009
Why does titanium white paint turn pink?
add drop of blue and this should solve the problem,
for future reference - what paint? aquarel? pastel? oil? acrylic? tempera?
solvent sometime can be a problem, if you use varnish - varnish naturally turns bit of yellow, sometime pinkish tint, but you need to check if solvents are compatible.
there is heaps of variables in paint mixes, you need to check purity of the pigment (rutile ore contamination's will tend to discolour pigment anything between brown and pink for example with the age), you need to check opacity of the paint (how transparent it is - background may cut through it and sublight it red), you need to check viscosity (light viscosity and dry pigment in wet on wet will "suck" paint from the background), all of these need to be check.
if you have more questions on the subject - you need to provide what medium you use and what is exactly effect.
hope this will help you - do not forget to vote...
Feb 20, 2015 | Crafts & Hobbies
Old elec. wiring is showing verdigris ( grease ) on the plaster surface! what do I seal the surface before painting?
ask your "local paint store" manager first...
if they do not know, I suggest washing down the wall, scratching it lightly with sandpaper after it is dry, then apply an alcohol based primer to seal the grease. I would then prime with a good latex primer before final coating. If you are painting pastels, or very dark colors (red, Blue, Black), tint the primer toi as close to the color you want.
Good luck
Neil
Sep 23, 2014 | Tools & Hardware - Others
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
Blue smears and dots on the screen and a orange yellow picture
Bad Light Engine/optical ASSY Encompass Parts Distribution 1-800-638-3328
Jun 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I checked my replacement bulb but it is fine, and
you have a bad light engine call Sony and see if it is one of the ones on extended warranty.
Aug 09, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Canon PowerShot A85 Digital Camera Logo
265 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
