Question about Acer Aspire 3680 Laptop
Acer aspire 3680 won't turn on / Black out.
Does anyone knows about if what components from motherboard should i replace?
  • 7 Answers
This line of Acer laptop has numerous power issues. If the laptop actually will not power you will likely need to perform some component level repairs. If it powers on but does not complete POST. (Meaning you dont see anything on the screen) Then you would want to begin by removing the center panel on the bottom case. Once removed locate your memory sticks and make sure that they are seated properly. Remove them and reseat them. Try to power the laptop again and see if your problem is solved. It is possible that if this does not work that the memory is actually bad and must be replaced. There are quite a few other things that can cause this. Memory is the easiest to repair. This failure can be caused by a defective CPU as well, but for the average computer user I would not suggest taking your PC completely apart. If you are comfortable doing so you will want to disassemble it, remove the logic board and use a test CPU to see if this solves your problem.
In case your unit actually doesn't power on it changes things. The first thing you need to check is the status of your AC adapter. If you do not have a voltage meter you would need to use a test adapter to elimiate that possibility. More likely the problem is caused by an internally broken DC connector. This happens very frequently and is a rather simple repair if you posses decent soldering skills. You can purchase one of these DC connectors from ebay for $2 or so. Disassemble the laptop, remove the two screws that attatch the DC board tp the main board. Desolder the DC connector and replace it with the new one. Sometimes this DC board will have been damaged from a power surge. In this case the entire power plane connected to the back pin of the DC connector will likely be shorted to ground. If this happens remove the old DC connector, cut off the back pin and solder and heavy gauge wire directly to the back pin. Run this wire around the DC board on the left side of the DC connected as you are looking at the connector fromthe front. On the other side of the DC board you will see 2 farite beads wired in parallel. They connect the shorted power plane to the next. Remove these two farite beads and run the wire to the contacts on the next power plane. This will bypass the damage to the DC board.
If the DC connector is the the cause for the problem. There is a pair of capacitors on the logic board that fail very often. To see them you will need to remove the heatsink assembly from the logic board. They are ceramic capacitors right next to the CPU socket. They are wired in parallel and may bot show any physical signs of damage. If you have a multimeter set it to test continuity and put both leads on eachside of the caps, if you hear a constant beep then the caps register as shorted. Remove them both from the logic board and repeat this process with them outside the circuit. If you touch the leads to each side of the caps and hear nothing, then the cap is good. If you hear the same continuous beep then the cap is shorted and is the cause for your power issues.
If these suggestions have not solved your issue, then the motherboard may still be repairable but will require an experianced technician to isolate the cause for the no power. Good luck.
Posted on Aug 02, 2009
Acer aspire 3680 notbooting black screen when power is on
if you can hear your fan noise when you start your laptop and cannot see anything on screen,that means your motherboard is faulty and you will have to replace your motherboard
Once you replace your motherboard,your acer aspire will be fine again
Thanks
Aug 02, 2010 | Acer Aspire 3680 Laptop
Acer aspire 3680 does not power up even the batt is fully charged?
There might be a problem on your motherboard particularly on the power supply area. Try to check if the item is still under warranty you can always ship them back the product. Laptop Motherboard problems might prompt you to buy a replacement motherboard.
Pls vist their site:
http://www.acer.com/worldwide/selection.html
Thanks.Cheers!
Apr 21, 2010 | Acer Aspire 3680 Laptop
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
I have an acer aspire 3680. when i turned it on, the fan,hdd works but the screen turn black. i did try to connect it a VGA screen but i's not on. is it the mainboard problems?
you may consider if no display at LCD and VGA monitor both:
1) you may change RAM or change the RAM slot
2) take out the wireless card from MINI PCI slot
3) still black screen that should be any damage of display chips or isolated memory (all BGA chips)on the motherboard
hope it help you troubleshooting
May 08, 2009 | Acer ASPIRE 3680-2022 Notebook
Acer aspire 3680 - cd/dvd reader doesn't work
You will need to purchase a replacement component either instore or on ebay.
Alternatively you can update your software and drivers from here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Thanks
C
Mar 22, 2009 | Acer Aspire 3680 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
1,627 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
