Question about Dryers
Kenmore series 90 electric dryer will start, heat up and then shut itself off after about 5 minutes
  • 44 Answers
Take the bottom of the dryer off and check for obstruction in heat tube. if it is loaded with lint it will overheat and shut down. Use vacuum cleaner and clean it out. Also take exhaust tube off back of dryer and check that the tube leading to the outside is clean with no obstructions. Check baffles on outside make sure there is noone living in your vent tube to the outside.
Posted on Jul 13, 2009
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore series 90 electric dryer does not heat and shuts off after several minutes of use. Heating element is at 9 ohms, spec is 7-11.5 , thermal limit switch was open. I replaced thermal switch and...
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
Feb 27, 2010 | Dryers
Kenmore 90 series electric dryer. Buzzez when you press the start. Sometimes it runs for a couple minutes then shuts off. is this the motor or a start capacitor?
Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 07, 2009 | Kenmore 659 Electric Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
156 people viewed this question
Top Dryers Experts
