Question about Ruud UAKA060 Air Conditioner
AC turn off before it reaches the desired temp
Why does my AC turn off before it reaches the desired temp?? After about 10 minutes off, it will come back on. Eventually the desired temp will be reached, but sometimes it will cylce on and off numerous times before it is reached.
  • tonspag Jul 13, 2009
    The indoor fan shuts off as well.
  • 73 Answers
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Thanks
Paul
Posted on Jul 13, 2009
  • 1 more comment
  • Paul McNaul
    Paul McNaul Jul 13, 2009
    Hi again. Hmm. It must be a thermostat problem.
    Thanks
    Paul
  • Paul McNaul
    Paul McNaul Jul 16, 2009
    OK. Replace the battery in the thermostat.
    Thanks
    Paul
  • Lily Lepp Jul 08, 2013
    I would like to know why the AC fan unit shuts off before my house reaches the temperature I sat up in my thermostat. I already cleaned the unit and still shutting it off! Remember the fan is shutting off !! Please help me!! thank you :)
My ac randomly turns off and when I restart it it does the same again
HOME A/C units are designed to shut off when the desired room temp is reached.it is called Cycling. when the temp control unit senses that the temprature is too high then it will turn the unit back on till it again reaches the temp it is set oto
Oct 01, 2015 | AC Cars & Trucks
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
Apr 29, 2015 | Kenmore Kitchen Ranges
"I have a White Rodgers 1F78-151 thermostat and for some reason the system keeps shutting off every few minutes and never reaches my desired temperature i constantly have to set it to off than back to
Is this a gas fired furnace? If so it may be going off because one of the safeties is tripped. There is a high temp safety that will shut the unit down when this temp is reached. The usual cause is low airflow. Check your filters, if these are OK you may have a blocked coil which should be professionally cleaned.
Feb 01, 2015 | Heating & Cooling
AC will not shut off when desired temp is reached. Have replaced batteries.
thats simple. this is caused by weak power button of board. let me know if you dont know how to do this.
May 31, 2012 | Heating & Cooling
Air conditioner shuts off early.
Hi, thermostats is not problem , it's asking for cooling when it should, it's your condensing unit outside, if mechanics said, system is o/k. then it's location of condensing unit, check location of your condensing unit, in relation to direct sunlight, condensing unit best location is always a cool place, preferable away from direct sunlight, check to see, when unit is doing that, if it's expose to direct sunlight, that could be your problem, direct sunlight for long periods could cause the high pressure & temp. controls malfunction. or maybe system is not fully charge with freon, double check freon charge. if direct sunlight is your problem, build a shade or change location of condensing unit, good luck.
Aug 02, 2009 | Ruud UAKA060 Air Conditioner
I have a magic chef 1.7 cubic compact refrigerator, it's been great, but I had quite a bit of ice build up on the little freezer compartment. I unplugged it, and used a hair dryer to melt the ice until it...
OK as long as you used a hair drier, and not a screw driver to defrost this machine, you should be fine, it shoudl take no more then 24-36 hours to regain the correct temp, this being said, not real comfortable with the over the internet diag of a unit that potentially "keeps people alive"
Jan 25, 2009 | Magic Chef MCBR170 Compact Refrigerator
Delonghi cf210 when setting temp it dosnt give any heay
just bought one.It looks like the thermostat has problem. Set at 78 F, it runs forever and the room temp is 72F. Set at 79F, it runs, room temp shows 73 F, sometimes 75F or 77F. The Ac is on then off every 5 minutes even the desired temp (is set) reached. Lousy machine.
Jul 27, 2008 | DeLonghi CF210 Portable Air Conditioner
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ruud UAKA060 Air Conditioner Logo
1,173 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
