Question about Motorola Radio Communications
Bluetooth Pairing from Motorola H620
I am trying to pair my motorola h620 headset with my samsung trance. I placed the phone's bluetooth on, and the device in pairing mode, and it connects and pairs sucsessfully. But sound still comes from the phone, and the headset displays a red light
shanth
  • 108 Answers
SOURCE: Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Posted on Dec 22, 2007
rockfixya
  • 679 Answers
SOURCE: motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
hmerchant110
  • 7191 Answers
SOURCE: Could you give me the
The passkey or pairing code is 0000 (four zeroes)
For more details, download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Sep 05, 2010
KHANtheGR8
  • 277 Answers
SOURCE: Can u give me the
Motorola handsets and accessories will use the following default passkeys: 0000 or 1234, if not, then check the fol link
https://motorola-global-en-usa.custhelp.com/app/answers/detail/a_id/21216/~/bluetooth-passkey
Posted on Sep 14, 2010
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
Dec 29, 2014 | Samsung Radio Communications
What is pin for pairing motorola h620 with iphone
motorola uses two different pin pairing codes, they are as follows 0000,or 1234.i hope this helps
Feb 26, 2011 | Motorola Mobility H620 Bluetooth Headset
I have the Motorola H620 bluetooth and it is paired fine, phone answer and dial and voice activation works fine, but, music will not play through the headset. When I play my ipod app in my iphone, music...
1)this feature not availeble
2)go to this link 100% sure solve your problem http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/H620/US-EN/_Documents/Static%20Files/H620_QSG_US_9518A57A.pdf
Nov 13, 2010 | Motorola Mobility H620 Bluetooth Headset
Can u give me the pAiring pin for m h620
Sep 14, 2010 | Motorola Mobility H620 Bluetooth Headset
Could you give me the pairing code for H620 Motorala bluetooth earpiece?
Sep 05, 2010 | Motorola Mobility H620 Bluetooth Headset
Need code for motorola h620 for the iphone 4
code is 0000. same for all Bluetooth headsets. Hope this Helped! Remember to Rate!
Aug 26, 2010 | Motorola Mobility H620 Bluetooth Headset
I need the passkey for the Motorola H620
Try 0000. I am sure that it will work as this is default key for all bluetooth devices.
May 28, 2010 | Motorola Mobility H620 Bluetooth Headset
I have a Blackberry Curve 8320. I purchased a Motorola Universal Bluetooth Headset H620 that is supposed to be Blackberry compatable. I am unable to get my phone and bluetooth paired. What do I need to...
It may be the pairing code that you are using. Usually it is 123, 0000, 1111, 1234, or some other variation.
Make sure, also, that you are in pairing mode with the headset. If you can scan via bluetooth and detect the device, then it should be ready to pair.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Radio Communications Logo
812 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
