Question about Whirlpool Duet GHW9150P Front Load Washer
F2 My washer freezes during mid cycle
F2 My washer freezes during mid cycle. It shows F2 and beeps. It will not restart.
  • 5,911 Answers
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. If the drain pump will not function, the washer will not complete, or restart a cycle. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Sometimes you may also get a "SUD" error in conjunction with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Posted on Jul 13, 2009
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
What to do when it won't restart and drain in mid-cycle
Try resetting by switching off at wall power supply
Sep 22, 2014 | Dishwashers
F2 Code???
Probably blockage in pump or sump
Jun 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during rinse cycle and beeps at me
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Stops during cycle
you must reduce water on faucet
Feb 16, 2009 | Kenmore Elite 45986 Front Load Washer
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool Duet GHW9150P Front Load Washer Logo
278 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
