Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
There seems to be no water preassure comming out of my krystal clear deluxe salt water system, model# 8111. What could be wrong? I have lost my manual and the system is indicating code 90.
  • 297 Answers
Sounds like air lock
disconnect skimmer ( if you use one) from inside of pool
make sure the tube going from pool to pump has no debris at the motor housing
hair can build up there then trap other debris
no open you bleeder caps till water runs freely
once water is coming out and you do not hear air turn on the pump
let run for a minute then close the caps
Posted on Jul 13, 2009
My krystal clear deluxe saltwater system model 8111 wont turn on
check power to unit if ok check voltage from transformer
Aug 28, 2017 | Pool & Spa
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
My Krystal Clear Deluxe Saltwater System Model 8110 is not turning on
My pump works, but it wont turn to chlorine, so it then turns the water green, i looked everywhere and cannot find a solution, anyone that can help that would be great.
Apr 23, 2011 | Intex Automatic Salt Water System for ...
Which salt water test kit(s) would you suggest for my 18'x52'' steel sided pool. i have a Krystal Clear system model CS8110 . what do you think of the salt strip readers?
Have the salt tested free where you purchase chemicals. While there, get a Taylor test kit to test for CL, pH, Alk, CA and Cyanuric Acid.
Salt is persistent in the water - translation - once in the water, it stays there, it doesn't go away except through splash out or back wash. Your salt should be around 3200 ppm. Get rid of the metals in the water before you do anything ... get the Alk around 100 then adjust the pH and introduce your CL. Cyanuric Acid protests the CL you are making. Some places call this 'stabilizer' and the reading should be around 60 to 100 ppm. Calcium is like salt ... persistent in the water ... lost under the same circumstances.
I hope this information helps you.
Thanks for your interest in FixYa.com. If this was helpful ... plese remember to vote and leave a comment.
Thanks
Aug 02, 2010 | Intex Pool & Spa
I have a saltwater pool The pump we're using is the Krystal Clear Saltwater Deluxe Model #8111. I need a owner's manual. Question: How can I get the green out of my pool I've vaccum and brushed the bottom...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
You should not blindly ad salt
you need a salt test strip that reads in #'s not color
get your water to 3000ppm any lower than 2800ppm and you will not generate enough chlorine
any higher than 3500 and you could get cloudy water and trigger high salt reading not to mention the bad taste
continue what you are doing in addition add 1 gl of liquid chlorine to shock the pool with cleaning your cartridge out every 4-6 hours
once it starts clearing up start using a non foaming algaecide every 5-7 days just use the directions on the botttle Since you already have an algae problem, even though it will be clearing up you should go for the maximum dose the first time
As for OUR pump/filter/salt combo it is a piece of ****
I do not know your gl of water but here is a generic set
a pool needs turned over 3-4 times minimum in a day
so if you have a 5000gl pool and our filter at 2000gl ph you need to run it at least 7 1/2 hours at bare minimum
I now run mine 24/7 I generate chlorine over night and filter during the day even when being used
also you should check the front of your motor where the hose goes in this catches debris and hair that the skimmer lets in
with these pumps you need all of the flow you can get
speaking of flow we do not get enough of it so it is very important to use the pool every day if you are not then at least brush it every few days once you are green free
another thing to do is once you get the pool back to swimable
Have your best swimmer get in and clean under the seems with a toothbrush inside the pool
in the liner you should have 2 seems in the floor and one around the bottom between floor and side
you now will have a build up of algae in these seems that will not completely go away with shocking since it is protected by being wedged under the seem
Physically lift and scrub
any more questions let me know
please remember to rate this help
Jul 19, 2010 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
What is the best model filter pump for an 18' X 48" intex metal frame pool?
No doubt about it the Intex Krystal Clear Deluxe Saltwater System & Filter Pump. No more chemicals to add and no more money to spend. Just buy salt. Could not be easier. I own one myself. http://www.intexcorp.com/saltwater_02.html
May 31, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
400 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
