Question about Refrigerators
Power failure in the area, everything is freezing in fridge
Power failure in the area, when the fridge came back on everything is freezing in the fridge even when it is turned down to 1
  • 10,865 Answers
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Posted on Jul 13, 2009
Why wont my freezer wont freeze everything else does
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Air needs to circulate in both parts (dependent on eachother)
Aug 29, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Hi, I have a kic super kool fridge freezer. Everything in the fridge is freezing. Temp in the fridge is on 3. What can the problem be.
The refrigerator side has an independent thermostat and that can be damaged from a power surge, natural age, or defective internal components. If you can change it out yourself do it! If not; call the service center for assistance. Note: Failure to act could render the fridge usless and cause problems for the compressor down the road.
May 10, 2014 | Refrigerators
Refrigerator area freezing anything I put in it. have it turned off still running.
Turn the refrigerator off at the power source - leave off for two days - clean the cabinet and then return to normal service - sometimes ice can form on the damper temp control stopping it from closing - this then allows to much cold air from the freezer to enter the fridge freezing everything in it - worth a try as a quick fix
Oct 22, 2013 | Kenmore Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Refrigerator freezer is not freezing,ice accumalates on one side of the back wall
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle
Sep 16, 2009 | Refrigerators
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer not freezing solid. Pulled off back
Your not going into defrost, the fridge cycles into defrost every 8-10hrs for approx 20mins....problem could be multile items, the defrost time, defrost thermostat, or the defrost heater, will need a meter to ohm heater and thermostat...thermostat will be a closed circuit when it gets below 22degrees. ohm the heater out...if both check ok, will be a timer issue. Can do a simpler check....in the fridge section near controls there is a smal hole with a gear on the inside....that is your defrost timer. take a falt tip screwdriver and turn that gear until it clicks, this will put the fridge into defrost...if everything on the heater side is ok you will hear a sizzle from the ice melting
Jun 09, 2009 | Amana ABB1921DE Bottom Freezer...
Hotpoint rfa18 Fridge Freezer
Is the back wall full of frost? If so you have a defrost problem, most likely the defrost is stuck in the run mode. this is located above the controls area in the fridge.
Nov 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
