Question about AKG C535EB Professional Microphone
AKG C535 microphones pop and hiss
We have a dozen AKG C535EB microphones, and half of them pop and hiss. This is not sibilance or wind noise, no one is talking at them.
It almost sounds like a failed electrolytic capacitor, but on half of our mics in the space of a year? This occurs on three different boards, any channel of any board. Phantom power is -48V, all of the mixers are Mackie (one 3208, others 1604).
  • 36 Answers
If they are "condenser" mic's, the condensor module, as in the case of capacitor, failed as time goes. <condensor = capacitor>. Might be a good idea to check other capacitors inside.
Posted on Jan 25, 2008
Surha AKG uhf ht 40 handheld mic
You need a pop filter while recording. There are different reasons why a "pop" would get recorded in the signal. Either because of the harsh P's and T's while singing or rapping like "Business", "Pain", "Property", etc. or it could be jitter problem due to an unstable clock. Mostly you would recognize these ones cause they don't sound like the pops coming out o a persons mouth. They're more like clicks. Your problem, from what I understand is due to the former reason. That's why you will need a pop filter.
Jul 06, 2014 | AKG Audio Players & Recorders
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
Mar 18, 2011 | AKG C4000B Professional Microphone
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
Hi I have a CAD VX2 that has intermitant noises showing up. they are quiet, but noticable. I have tested it without the mic attached to the power supply and i get NO noises.... the noises only show up when...
Condenser mics will not generate ANY audio, noise or otherwise without a power supply... so that test may be moot.
You have not described the noise so I will try to cover possibilities:
1. ALL electronics generate a random thermal noise which is a limitation of physics. This noise is a random "hiss" for lack of a better description. The level should be many Db less than normal program.
2. Wind noise due to air flow or singers popping... you can sometimes shield this or use pop filters for singers.
3. Crackly noises are often caused by bad cables or connectors... I recently found 6 of my mic cables were MISWIRED so they basically were unshielded/unbalanced. Check that your cables have the shield on pin #1 and the other pins connected respectively at both ends.
PLEASE google the connections for XLR cables and pin arrangement as they are weird layout.
Some cable is of poor quality and generates more noise due to poor shielding and inadequate twisting of the signal pair.
Jul 19, 2010 | Dual CAD VX2 Valve Multi-Pattern Condenser...
Excessive line crackling noise
The service manual is at You will have to replace the wiring that goes to the cartridge through the gooseneck.
May 25, 2009 | AKG C419L Professional Microphone
Hissing noise in the microphone.
my mic was plugged in the front panel of my pc. it was producing that hissing noise. then i plugged directly into the sound card at the back of the pc. problem solved.
Mar 18, 2009 | CAD Microphones GXL1200 Professional...
Lots of white noise and crackles, and intermittent problems.
check and make sure on the back of the power supply that it is set up for your local voltage(120/240)
Sep 06, 2008 | AKG SolidTube Professional Microphone
AKG C535EB Professional Microphone Logo
561 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
