Question about Margaritaville Frozen Concoction (DM1000) Blender
I broke the teeth on the base that turn the mixer blades on the pitcher
    Problem Solver:
  • 5 Answers
Just ordered a part from culinary parts unlimited at 800 543 7549
Posted on Jul 15, 2009
  • dain582 Jul 15, 2009
    it was on back order but paid $15 with shipping
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Where do I find a replacement pitcher?
Link, Can you tell me what brand your blender is? This is usually found under the blender base or right on the front where the buttons are. Then we can tell you whether there are replacement parts or not.
May 08, 2015 | Blenders
Doesn't turn easily--sounds a bit labored
If the same problem exists when the pitcher is not on the base, the base needs to be replaced. It could be that the blade bearing is dry/rusty. In that case replace the blades. Either way, continuing to run the unit in this condition will fry the motor.
Jul 31, 2013 | Braun Blenders
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blade not turning
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Feb 21, 2008 | KitchenAid KSB3 Classic Work Top Blender
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Dec 27, 2007 | VillaWare 5787 Double Smoothee Work Top...
Margaritaville Frozen Concoction (DM1000) Blender Logo
1,039 people viewed this question
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
