Question about Bunn 10 Cup Home Coffee Brewer
GR-10 Bunn coffeemaker: Heating element is split open. Touching water gave me a shock. Where can I get parts? Are they even available?
  • 189 Answers
I do apologize but the part you are looking for is not available. Please look at the bottom of the brewer for the model and date code. Then contact customer service so that you can be assisted further. The machine carries a 3 year warranty so if it is 3 years old or less it will be replaced at no cost. If it is older than 3 years, it will be replaced at a reduced price.
Posted on May 19, 2010
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My Bunn coffee maker just quit. No hot water, no brewing sounds, no heater. Is it the cord or is it just done? Help!
Unplugged, check the wire connections, heating element and thermostats
You need to have a volt meter for this job.
Jan 18, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
Jun 18, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker reservoir makes a gurgling noise
THis sound is usually caused by the water being low in the tank. This can be because the machine is left on for long periods without being used. If this is not the case, then it would probably be your heating element getting small holes in it.
Jan 12, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
HEATING ELEMENT IS RURNED OUT
You can order a new heating element from the manufacture. But, the crimp connectors and the thermo-fuse may also have to be replaced. You will need the crimp tool for the crimp connectors. You will also need a meter to verify the connections.
If you take the unit to an appliance center they can service it for you. But, you may find the cost of the parts alone to not be feasible.
Jerry G.
Jan 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Warming Plate
actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
Jan 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Oct 27, 2007 | Bunn RL Coffee Maker
Bunn Coffeemaker CWTF35-4
Hook it up to cold water. It has a heating element in the tank that heats the water.
Oct 24, 2007 | Bunn RL Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
396 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
