Question about Bose Lifestyle 48 System
Color when watching a DVD
Color on my TV is working great but when I put a DVD in my Bose system there is some color but looks more green than anything. What could the problem be?
  • rreiland
    rreiland Jan 14, 2012
    I have the same exact problem - mostly green when playing DVDs. No problem with TV.
  • 93 Answers
Maybe you need to set "TV SETTINGS" in your DVD unit menu (i.e. PAL / SECAM / NTSC)?
Posted on Jul 14, 2009
  • rreiland
    I found a loose cable, problem fixed - works like new now.
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
DVD and Menu screen color settings are not right. We recently had the local Bose store set up our Lifestyle 48 system and all was well but recently the screeen color, when in menu mode, has changed from...
Jason.... there seems to be a connectivity issue and i could not see any of your messages in the chat box.......
for reconnecting the unit... please refer to this link below
http://products.bose.com/pdf/customer_service/owners/ls18ii_ls28ii_ls38_ls48_install.pdf
the Surround speaker cables have orange RCA connectors at one end and speaker plugs
at the other end with L (left) or R (right) markings
Jul 31, 2010 | Bose Lifestyle 48 System
When playing a dvd the color is in b&w only
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the Lifestyle system 5 years ago.
Good luck
Peter
May 15, 2010 | Bose Lifestyle 38 System
BOSE 321 DVD movie movie picure is blue. Its connected to a Sony LCD digital Wide screen TV Bravia Model KDL 40V2500 and my cable box. Could it be a loose connection.
Sounds like you are using a component cable(red,green,blue) rather than an HDMI cable.
Component cables are fine to use but if one of the 3 cables is disconnected, loose or bad, you may see blue video.
Check for loose connections or bad cables and make sure the proper color is plugged into its matching color.
Oct 25, 2009 | Bose 3·2·1 II System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
On my Bose Lifestyle 38 color is different.
Try a different SCART lead, if not try connecting to a different SCART slot on your TV.
If the problem persists I'd contact bose and have them repair it, its not worth taking apart a three grand system if you are not sure what you are doing.
Nov 27, 2007 | Bose Lifestyle 38 System
Bose Lifestyle  48 System Logo
286 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
