Question about Refrigerators
I have a RM 2811 2 way dometic is operates fine in A/C mode no
I have a RM 2811 2 way dometic is operates fine in the A/C mode but when switching to LP gas it does not work both 30 lbs tanks are full and there is a flame at the the base of the flue I felt the flue and it does get hot What could be wrong and how do I fix It thanks in advance Frank Del Masto
  • 73 Answers
Hi there. When calling for cold, flame should be large and blue. If orange, clean mixing tube, flue, chimney. If still orange, adjust "air" inlet on mixing tube to get blue flame.
Thanks
Paul
Posted on Jul 13, 2009
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
RM 2611
the relay for the ac powered heater is stuck closed. it should cycle on and off , and not be on at all with the unit off.
Apr 17, 2014 | Dometic Refrigerators
Dometic rm 2811
Hi!
The air regulator door/flap/shutter, what ever they call it, is not working or the temperature sensor for this device is not working.
Good Luck Richard Tramutola
Jun 10, 2013 | Refrigerators
RM 2804 model, does it have a fuse?
under black cover in back possible heater element
Jul 14, 2012 | Dometic RM2652 Refrigerator
I have a dometic rm 2401 and it won't work on
yes, pretty common issue with that model
May 10, 2012 | Refrigerators
Dometic refrigerator model RM 2193 for RV works only in the DC and LP Gas mode. two days ago the AC mode was still working and stopped yesterday (outside temperature was about 40 degrees...
Hi and welcome to FixYa, I am Kelly
Operators manual:
http://www.gas-refrigerators.com/pdf/RM2193-manual.pdf
Parts manual:
http://www.scamptrailers.com/Portals/0/Dometic_Refrig_RM2193_PartsList.pdf
If you look at the last page of the parts list (page 10) it is showing a thermostat across the Black and white wires.
There is not a fuse that I can see. The fuse has to be external to the unit. You should be able to read continuity (resistance) of the AC heating element at the power cord with the AC switch ON.
AC Power source must be removed to perform resistance checks.
No continuity there are 2 possibile failures (Other than wiring)
1. AC heating element
2. Thermostat.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | Dometic Refrigerators
Dometic 2811 gas/AC refrigerator poor operation on gas mode.
Your gas valve is sticking. Could be a bad thermocouple.
Set it to come on, then with a screwdriver handle or something similar, tap,tap,tap gently on the gas valve to see if it lights.
Once it unsticks it should operate OK.
If it does not unstick, replace the gas valve.
May 26, 2009 | Dometic Refrigerators
Model RM 2811 Dometic refrigerator for lp-gas and electric operation: problem is that the control pannel switches rendomly from auto AC to Gas and I want it to operate on AC only. trailer os located...
One problem may be high dc volts it should be around 13.5 max your convertor may be developing to much voltage. Relay is on dc side you have more than enough. The contol board would be your next check. Some places that sell them may be willing to check if you bring it in.
Aug 28, 2008 | Refrigerators
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
