Question about GPX D1816 DVD Player
Blinking standby light, dead dvd player
Our dvd player is all of maybe a month old, and though we have it plugged into a surge protector, after a storm hit and knocked our power out for a couple hours, the standby light began blinking steadily, and nothing tried will rectify the issue. tried unplugging but apparently the issue cannot be reset.
    President:
  • 846 Answers
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Posted on Jul 13, 2009
Standby light blinks 4 times
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green light keeps blinking will not turn on at all
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
May 11, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Standby light keeps blinking but no picture
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
Kdl-52xbr4 5 blinking standby lights
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
Green blinking light
Oct 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
4 fast blinking lights
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
10 BLINKS AND GO DEAD
Standby tech diagnostic codes.
Panasonic seems to be having some issues with this on newer sets.
They are a good brand but this is not very good and pretty common.
Do a search for Panasonic TV codes
Usually its related to the current and circuits to fire up the set.
After unplugging for a time, a few hours maybe over night. A few minutes may not be long enough. Try plugging directly into a wall outlet by itself, do not use a surge/protector or power strip.
Some have success by even moving connections around such as DVD player or cable box to a different port.
This is worth trying if the TV is out of warranty because truly it could work but check out the codes for 10 blinks first. The number of blinks tells what the problem is. I do not codes for Panasonic.
I have a similar problem that is extremely common on my Sony and it wouldn't start, 6 blinks. Removed it from surge protector and plugged other equipment in a different outlet.
I have plugged directly into the wall and it will fire up now, When I am done I unplug at wall to reset standby. The set is not worth the $500 bills to repair so until is, yours may be.
Aug 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
GPX D1816 DVD Player Logo
449 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
