Question about LG V181 DVD Player/VCR
Time and Date
Cant seem to get the time and date to show up on the burnt dvd when transferring family video from DV to DVD. Time and date id appearing on Dv but does not appear on the burnt dvd.
    Novelist:
  • 111 Answers
You will most likely need to add a title in your video editor to display this, the time and date id are usually overlayed on your camera and can be disabled if need be. the camera uses it's internal clock to imprint the video, this seldom if ever transfers to dvd unless the application you are using supports it and you enable it.
hope this helps,
trin
Posted on Nov 16, 2007
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
I have a dcr-sr200 and have 7 hrs worth of video to burn that took about five hours. But when I check it the time date stamp did not appear. I can seem to figure it out . please help
I understand that you have burned the videos to a disc using Computer and the burned videos does not have the date and time on it. In order to get date and time on videos taken using the Hard Disk Camcorder, the video should transfer using A/V interface with the DATA CODE option on the Camcorder enabled.
Once you enable DATA CODE, the date and time will be shown when playing videos in the Camcorder. You can view when you connect the Camcorder directly to a TV. While using the A/V interface with Computer to capture videos using an Analog Video Capture Software like Windows Movie Maker, you will get the videos in Computer with date and time displayed. You can burn those videos using a burning software.
If you're using stand alone DVD Recorder, you can enable the DATA CODE and use the A/V interface to connect the Camcorder to the DVD Recorder to get the date and time on videos.
Thanks for understanding. Please let me know for clarifications. You can also give more information about the recording method you're using to give more specific instructions.
Apr 30, 2011 | Cameras
How is the time/date stamp displayed on a copy
The time/date is 'stamped' onto the video during recording. The time/date stamp function can be turned on or off in the setup menu. If it was 'on' during recording, it will be displayed when played back. If it was turned off, it will not be seen on the recording.
Jul 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
No date stamp
Use ENESOFT DV PROCESSOR. (It's free, I don't work there LOL)
Oct 12, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Getting Date & Time Stamp on to DVD
If the date and time appear during playback to a television from the camcorder, we discovered that the date and time stamp can be recorded during playback through a DVD Recorder.
May 10, 2008 | Video Cameras
DAte/Time stamp
I was having the same problem, and was tasked to find a solution at work.
I ended finding talking with a developer who wrote a custom utility that can extract the time/date data from the .MPG (it's hidden in there somewhere) as a special txt file.
Here's a link to that utility: (special version for NTSC footage):
http://dl.free.fr/pNo24JrdB (Special thanks to fnx91 on the videohelp forums)
Then you import that file into a piece of software called DVSubmaker which will convert that data in a special format (.sub) used by certain DVD/Video players to display subtitles.
Here's the best 2 options for playback:
1. Windows Media Player (need Mpeg2 codec) combined with a plugin called Vobsub - Free:)
2. ZoomPlayer (DVD Software) - $60
So in a nutshell, your displaying the original time/date stamp as subtitles on top of the video.
Contact me if you have any troubles.
Feb 22, 2008 | Sony Handycam DCR-SR82 Camcorder
GO VIDEO DV 2140 VCR DVD COMBO
Are you inserting homemade burnt dvd's ???
Nov 25, 2007 | GoVideo Go Video DVD/VCR Combo
Need help on setting the date and time when you record it into dvd.
You need to add a data code. put your camera into play/edit. choose MENU>DATA CODE.
Jan 27, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Data code problem pleeeeeeese heeeelp......
Here are some programs that might help you with your problem : DV Sub Maker (Freeware) from Mike Laba aka Krong makes DVD subtitles from DATECODE in SUB or SST format which can be used in Scenarist and ReelDVD. DV Date Time Changer can change the DATECODE. And the test version of Play DV shows the DATECODE when playing DV AVI files. See http://video2dv.com/ DV Date, (old name DVRecDate) a shareware Adobe Premiere plugin from Ilia Topolnitski stamps DATECODE in videos. A DVD Subtitler (also shareware) exists too! See http://dve.teletex.ru/
Sep 14, 2005 | Sony Handycam DCR-PC5 Mini DV Digital...
LG V181 DVD Player/VCR Logo
54 people viewed this question
Computer Repairing
Computer Repairing
