Question about Bosch 7 - 1/4" Skilsaw Circular Saw
Where is blade lock for my Skilsaw 5150 located
  • 10,865 Answers
Look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Posted on Jul 13, 2009
    New Friend:
The 5150 did not come with an arbor lock. The manual clearly states. Do not over tighten. Give a quick blow to the included tool to loosen.
I just set my blade to catch my wood work bench by a 1/16" or so and give the tool a quick tap. Works fine if you keep everything clean and lubricated.
Posted on Jul 15, 2014
I did not see a lock button on my model. (Are there other Skilsaw model #5150 that have this? If not, why even post this as a possibility?) Luckily my blade did have a hole in it to insert a screw driver. I had to turn the blade just right in order for it to catch. The old blade came off great, but the new blade I just put on did not have a hole. I had to stick the screw driver in one of the teeth perpendicular to the blade nearest the body while I tightened the nut.
Posted on May 30, 2012
  • Bosch Master
  • 1,932 Answers
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Mine is absolutely stuck. tried putting everything in the hole including a screw and it broke my socket trying to loosen it clockwise as stated. why skil never put a blade lock on these is beyond me.
Posted on Aug 26, 2014
4 Suggested Answers
  • 15 Answers
SOURCE: Where is the blade lock button on a skilsaw 5150 2
I have that saw just stick a screwdriver into one of the teeth perpendicular to the blade and when you tighten the bolt it will keep the blade from turning works like a charm .
Posted on Jul 07, 2009
  • 15 Answers
SOURCE: How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Posted on Jun 08, 2010
  • 313 Answers
SOURCE: Removal of Blade
turn the blade screw same direction as the blade rotation if you want to remove it.
Posted on Sep 19, 2008
While I'm cutting a 2x4 the blade stops or catches on something? It's happened so many times.
Dull Blade most likely
Wrong Blade maybe
Wrong cutting depth setting on blade
or the way your using the saw
Oct 29, 2014 | Skilsaw "5150" Circular 7 And 1/4 Inch
How to replace the guard spring on skilsaw 5150
trial and error and lots of patience with tweezers or small needle nnose pliers
Aug 14, 2014 | Skilsaw 5150
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
On a skilsaw 5150, I'm just trying to see if it
Hello, No such thing as a "dumb question"... everybody learns something for the first time. The safety is a button located just behind the trigger mechanism ( about where your thumb would be during operation) and must be pushed prior to squeezing the trigger. Since it is a selling feature of any item to have an operator's manual with the item, I am attaching the link to the english version.
http://www.skileurope.com/common/manuals/_Private/5150/5150-GB.pdf
Hope this helps!AYEUH
Aug 19, 2011 | Skil Saws
How do you tighten the blade bolt on skilsaw model 5150? Thw shaft just turns and won't tighten.
There is a button on side that lock blade . Push on button turn blade by hand till you feel button engage now you can tighten bolt left hand threads
Jan 26, 2011 | Garden
Jun 07, 2010 | Skil Saws
Blade change skilsaw 5150
The locking button on this saw is designed for safety. If you are attempting to change the blade it should NOT be plugged in. It sounds as if someone has pushed the lock button while the motor was running and sheared it off.
The only tool that is required to change the blade is the supplied wrench or an equivalent box end. If you cannot make the repair yourself for have the equipment repaired you can take a pair of vise grips. (Use cardboard to prevent warping or gouging the blade) and clamp the edge of the blade below the teeth. The vise grips will stop at the front of the saw as it is too large to pass by the guard allowing you to loosen the nut. Clamp the new blade in the same way only the back of the saw will be used to tighten.
I highly recommend that you either repair yourself or have the tool repaired by a professional.
Parts schematics are all over the net for this tool, here is an example:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/skil/5150
As you can see most of the mechanical parts are only a few dollars and it could save you from serious injury during operation.
Feb 13, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Removal of Blade
Sep 18, 2008 | Blade Saws
Bosch 7 - 1/4" Skilsaw Circular Saw Logo
11,228 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
