Question about Car Audio & Video
Auto radio How does one set the time on a factory radio for a 1987 pontiac 6000le,which stills works & sound great.
  • 709 Answers
Turn the power off on the radio with the Keys in ignition and turned on. Press the set button. Use the search buttons to set the hours or minutes. It might be another button set.
Posted on Nov 24, 2007
Replaced modular under coil pack. no go. Can packs go one at a time ,or all at one time. 1989 6000le pontiac 2.5
It is highly unusual for them to all go out at once. If you have changed the DIS module, you might try the crank sensor.
Dec 03, 2015 | Pontiac Cars & Trucks
1987 Fiero GT radio stopped working. Power button shows the station when pressed on clock when off, but no sound. If I move the fade or balance knobs with the volume up, I can hear some static...but no...
Double check for fuses in harness to radio & in fuse panel, as there is usually 2 different wires for power. One has constant 12 v+, the other only when key is on, perhaps the one that is powered only when key is on, has blown.
Jul 26, 2009 | 1987 Pontiac Fiero
Radio and horn will not work
I had the same exact issue today on my 86 Fiero. The Radio and Horn stopped working same time. There is a 20 amp fuse that is marked for the Horn but no mention of the radio. It is in the middle of the Fuse box. 86 -88 should have the same fuse box. ( If you reference the Chilton book they say the fuse is for Horn Cigarette lighter etc. but again no mention of the radio) I just happened to check this fuse (It was blown) and sure enough everything came back. Hope this helps......
Fiero R12
May 21, 2009 | 1987 Pontiac Fiero
Car will start runs good shut engine off will restart after awhil
try replacing the cpu behind the glove box $75.00
Apr 26, 2009 | 1987 Pontiac 6000
Factory radio with no sound
one of the positive power wires to the speakers is shorting out.alot of times it's the door speaker wires.
Mar 08, 2009 | 2001 Pontiac Grand Am SE
Timing a pontiac 6000le 2.5 engine
first check to be sure the vavuum lines at the throttle body are in there correct places.
on the main pulley of your engine, the one on the crank shaft there will be a little notch on it. mark the notch with some chalk or a dab of white paint. then loosen the bolt that holds down the distributor until you can turn the distributor. turn the distributor a little bit, snug the bolt up and try it. once you have the car running you will need a timing lite to set the timing to the correct timing mark. which should be 8 degrees before top dead center for you car.
Oct 09, 2008 | 1988 Pontiac 6000 Wagon
Radio doesnt work
Make sure the headphones are connected, since they are the antenna. If you are in an indoor area, the potential for picking up stations is greatly reduced.
Jun 04, 2007 | Philips GoGear HDD6330 MP3 Player
Car Audio & Video Logo
137 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
