The picture does not go out but gets bright enough that it is hard to see except around the edges where it is still normal.
SOURCE: Picture stretched on right and left edges.
I have a 32 inch Akai that does this from the built in DVD player mode I would try to get into the advanced video options on the menu I don't have a remote so I can only advise that far
hope that helped some.
SOURCE: picture brightens then darkens
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
SOURCE: samsung LCD model #LN32A330JIDXZA has a very bright color, can hardly see the picture
My problem began the same way, then the tv turned off everytime I tried to turn it on. First I opened the tv, made a list of all the electrolithyc caps values and temps in the power board and gone to the store and bought all except the bigger one (like USD 8) changed all the caps and then the tv didnt turn off again but image was all white.
Then searching in youtube found about the t-con board issues but the entire card was too expensive to dump so searched how to repair the t-con and found I can change the main chip so bought 2 in ebay from china took like one month but was just USD 8, so carefully cut all the old chip legs, retired the chip, used a soldering iron to retire the old legs, cleaned, put bits of new solder in the tracks, placed the new chip and began to paste leg by leg, tested continuity and checked for solder bridges between legs, assembled, turned on the tv and half screen has strips bot the left side was ok so rechecked flex cables between t-con and lcd and found bent tracks, carefully repositiones, assembled and now my mom has a brand new samsung 32in LCD to watch CSI and stuff... Sooo F_ck u Samsung LOL
Hope you can repair yours, every problem is a world so may not work for you but for USD 8 in chips, patience and some pulse soldering i think it worth the try.
