Question about Frigidaire GLEB27S7A Electric Single Oven
Kenmore Oven 9114658813 30" electric slide in model. What is an error code F3?
  • 10,865 Answers
F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Posted on Jul 13, 2009
I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
Jan 12, 2012 | Ovens
E1 F3 error code
F3
- E1 Oven temperature sensor (RTD) shorted
(upper oven, if double oven)
Replace
Note: Applies to all
F3-E... codes
Feb 08, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
F3 code model 9114558819
The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.try replacing the sensor first yu can have it mailed to you directly from marcone appliance parts
Jul 25, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore oven showing an F3 and later F5
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven displays F3 and beeps
f3 error code is generally a bad oven sensor. not every code is universal, but most manufacturers use the f3 error code to indicate a sensor issue. it is an easy fix if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire GLEB27S7A Electric Single Oven Logo
315 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
