Question about Sony Playstation 3 (PS3) Console
PS3 No audio video
My PS3 was working lately and now when I start it up I just get a Green light. Tried to restart system by holding in power and nothing helps. My Hard drive was working just fine before. Is there a solution without paying Sony $150.00?
  • 65 Answers
This problem happens with some of the PS3's and it is a motherboard issue. The PS3 motherboard needs to be reflowed using a reflow station. I have one of these stations on it's way to be able to fix this issue if you still have this problem. You can contact me at ced70@hotmail.com for more details.
Thanks,
Ced
Posted on Jul 13, 2009
How do i fix my PS3 when I cant see anything, but the system itself looks to be functioning?
You are going to have to do a video reset. Witch takes the video settings of the system back to default. To do this, make sure you have everything hooked up. Power, HDMI. Then, turn the system on, push and hold the power button until the system turns off, then push and hold power button until you hear 2 "beeps" then the video settings will be refreshed. ^^
Jul 14, 2014 | Sony Playstation 3 (PS3) Console
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Will not play without using HDMI cable
  1. Make sure the AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the AV Cable into the yellow Composite port for video, and into the white and red audio ports (if your TV does not have the red port, simply ignore it) on the back of your TV.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
No video or sound
Hello.
Most likely this is an output problem. But I have had 1 PS3 that had a bad hard drive and it wouldn't even load to the XMB. So try another hard drive and see if that works. Even a swift smack to the old one may work. If that doesn't work try the video out reset.
Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
Hope this helps. Good luck!
Aug 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 doesn't appear on screen. Possible power issue.
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Jul 27, 2008 | Sony Playstation 3 (PS3) Console
Picture but no sound
it happens to me alot lately i think its the actual hdmi port of the ps3 just unplug the hdmi cable and plug in and it should work just fine.
Jun 18, 2008 | Sony Playstation 3 (PS3) Console
Ps3 no sound
I had the same problem and tried everything and in the end turning off my tv and turning it back on again worked.. I also have HDMI setup through a samsung 1080p tv... I hope this helps someone :) I was so frustrated till I figured it out ;)
Feb 15, 2008 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
100 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
