Question about HTC Touch Cellular Phone
My touch screen is unresponsive [LG glimmer]
I was texting and sent a text and then all of i sudden the screen stopped working. The menu buttons at the bottom wont work and neither will the gray arrow thing about it.. But i can move the clock on the left side of the screen but it wont go past the mid line of the screen. My key pad works and i can send calls that way and when i bring up past calls i can scroll and click on their names. I can also read texts but i cant respond to them.
I have this all the time: 1. Inbox/ sent msgs are 2 full - so delete msgs 2. remove the battery out & clean sim card 3. If that doesnt work get a new simcard 4. if else fails- get a new phone
Posted on Jul 13, 2010
Samsung Galaxy Core Prime stopped sending texts, will receive them, how do you fix this?
The message centre ensures that your text message is sent to the recipient. If the wrong message centre number is saved in your phone, the text message can't be sent.
Set up your phone for text messaging Find "Text messages" Press the message icon.
Press the menu icon.
Press Settings.
Press Text messages.
Save the message centre number Press Message centre.
Key in +35387699989 and press OK.
Return to the home screen Press the Home key to return to the home screen.
Feb 04, 2018 | Samsung Cell Phones
My texting is messed up.
it means your msg, not deliver or not sent so you have to reset your massage setting
Jun 07, 2017 | LG Xpression MobiPhone - Red at&t
A gray block is in the middle of the screen
You probably have the "captions" or "text" feature turned on. Go into the menu and select "close captions" or CC and select off
Nov 10, 2011 | Televison & Video
White screen
This issue only occurs when trying to send a SMS text message from within the call details screen of a call in the call log.
To avoid this issue, complete the following steps to send a SMS text message from the call log screen:
  1. Open the Phone application.
  2. Open the Call Log by clicking the middle button in the toolbar.
  3. Touch the call log/contact in the list without clicking the screen.
  4. Display the menu, then select SMS Text (Name/Number).
  5. If required, rotate the BlackBerry smartphone to switch to landscape mode.
Oct 27, 2009 | RIM BlackBerry Pearl 8100
LG Vue touch screen doesn't work anymore
I had this problem last week. Though I have had mine for over a year. It is not a fixable problem. I hope you included insurance with your phone purchase because I was told it most definitely needed to be replaced. I got my new one, they sent it overnight delivery.
It was so frustrating not being able to see my texts and dial a phone number that was not in my call logs.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
I cant recieve my text messages using my sciphone i68
first off need to know what cellular provider you are using, 2nd all text or picture text. regualar text is classified as SMS pic text is MMS. You may have a corrupt setting, but ill take a guess and post T Mobile setup. if you use someone else dont use these settings.
SMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap SMS on the Messages menu.
3.) Tap SMS settings on the SMS menu.
4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting
up at this time for SMS messaging.
5.) Tap Profile settings on the SIM1(2) message settings menu.
6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the
screen.
7.) You should be on the Profile name menu with the name field already highlighted. Go
ahead and tap the Edit button at the bottom of the screen.
8.) Tap in the following text between the quotes in the Profile name editor:
“T-Mobile”
Next tap the Options button at the bottom of the screen. Next tap the Done button.
You should be back on the Profile name menu with the new name.
9.) Tap the area below the profile name. The top of the menu should change to read SC
address and the bottom of the screen should show a numeral keyboard.
Tap in the following text between the quotes in the SC address editor:
“+12063130004”
Next tap the OK button at the bottom of the screen.
10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
You are done setting up SMS messaging for T-Mobile. You can continue
to tap the Back button on the bottom of the screen until you exit out of all
the menus to the main screen, or simply press the On/Off button once to
get back to the main screen. At this point you can test SMS messaging by
sending yourself a text message, or continue with other setup of the
phone.
MMS Messaging:
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Sending Message Problem!!
touch the START menu on the top left of your screen, touch on MESSAGING, select SMS/MMS account by touching, that will take you to your inbox. then just touch the MENU on bottom right of screen and select NEW... then touch SMS. It will ask you to add contact 1st. then touch screen where text goes till curser appears then type either by keyboard buttons or middle bottom of screen if you touch a electronic version of keyboard will appear you can use stylis to type on screen keyboard. Then bottom left of screen hit SEND. message sent message will come on screen when msg sent.... Goodluck
Apr 10, 2009 | Sony Ericsson XPERIA X1 Smartphone
Cannot remove number in the sent IM menu of the LG Rumour
Click on messaging icon from main menu.
Click send message.
Instead of clicking text message click on pic/video message.
then you have 4 options TO: CONTACTS , TO Mobile#, To Email, And finally To Recent lict. Click on recent list and checkmark all the numbers you want deleted then click options bottom right corner then click delete.....
All finished hope this helps.
Jan 05, 2009 | LG RUMOR Cellular Phone
Sony Ericsson K850i screen & pad problems, please help !!
replaced the keyboard nd reflash the firmware on the phone.........take the phone to a mobile service shop and have it done
Aug 21, 2008 | Sony Ericsson K850i Mobile Phone
HTC Touch Cellular Phone Logo
615 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
