Question about Canon PowerShot SX1 IS Digital Camera
In M manual mode lcd and viewfinder is all washed out--but ok in auto mode what to do
  • 390 Answers
Hi
the changes to the Shutter and Aparture settings have set it to an open aparture n i think with low shutter
well i think u can reset the settings of the camera so that every hting gets back to normal and and u can start experimenting again
happy photographing, ejoy
cheera
pls rate if this was any help
Posted on Jul 13, 2009
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Canon 450D viewfinder out of focus due to loose element within viewfinder, is this repairable
There's a diopter adjustment knob above and right of the viewfinder. Turn the knob while peering through the viewfinder until it comes into focus.
Jul 29, 2012 | Canon EOS 450D Digital Camera
If you're using the screen to set up your shots, the viewfinder is disabled, and vise versa. It only works one way at a time. MY Question is, where do I actually go to disable the LCD or the viewfinder?
Set the shooting mode to a Creative Zone mode. Under the Settings tab select [Live View function settings] and press OK. Select [Live View Shoot] and press OK. Select Enable to use the LCD or Disable to use the viewfinder.
For full details, please see the "Live View Shooting" section in the manual.
Oct 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Large viewfinder only works when reversed &
dear ... there is an option in the menu .....
of hvr A1 TO KEEP THE VIEW finder.... ON..
write nw
ur camcorder is in auto mode ,wht happen in auto mode is ,view finder gets ON only when u turn the LCD pannel ...
so need nt worry change ur MENU option OF view finder from AUTO to ON,......
Jul 13, 2009 | Sony HVR-A1E HDV Digital Camcorder
Manual Shutter Priority Settings
Try the PROGRAM MODE-SPORTS setting. this will keep the shutter speed reletively high unless there is little light. Or use APERTURE PRIORITY MODE with an f2.0 to f2.8 to keep shutter speed high. If pictures were blurry when it went to AUTO then the light had to be low for the camera to select a low shutter speed. If using flash use forced or auto flash not slow sync. Also set ISO to 400 which is >>>. If inside use a larger external flash as the one on-camera is only good for about 10ft. if more than 10ft. away set focus to manual infinity so you don't have to wait for the camera to focus. Hope this helps.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Manual Shutter Moves
That is exactly what happens if you turn off the LCD. It goes into AUTO EXPOSURE. The same thing happens if you are in SHUTTER PRIORITY MODE. APERTURE PRIORITY MODE keeps your setting when going to just the viewfinder. I guess they did this because there is no way to change your settings with the screen off. It would be nice be able to keep those settings for situations where the light is not going to change and you want to save the battery. On the other hand, in manual mode I like the confirmation screen to be sure that the light didn't change.
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
LCD monitor and electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
Using the camera screen (LCD) as a viewfinder
To use the LCD as a viewfinder: Turn the Mode dial to any Still mode. Press the OK button to turn on the camera screen. Frame your subject in the LCD. Press the Shutter button to take a picture. NOTE: Using the camera screen as a viewfinder significantly reduces battery power. Use it sparingly.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Canon PowerShot SX1 IS Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
