Question about Gateway M305CRV Notebook
Gateway p-6301 need to replace dvd drive, how?
I have a gateway p series with a bad dvd drive, how do i go about replacing it?
There is a single screw on the bottom of the laptop hidden by a little rubber cover. pry out the rubber cover and unscrew one small philips head screw, then the unit slides out and you can buy a new one to replace it.
Posted on Sep 15, 2009
I need to replace my Gateway W6501 CD DVD RW Drive
power down unplug, open case, might need to open both sides, undo screws, pull plugs off, slide out replace, close up power up
Mar 14, 2013 | Gateway Computers & Internet
Cdrom download doesnt work
What are you tring to download? With what software? Need more info.
Jan 04, 2013 | Gateway P-series P-6301 17" Notebook T2310...
Burnt dvds read as blank. Sometimes work, but usually don't. can go either way with the same dvd at different times. It can and has happened with purchased cd and dvd. Though less likely.
Your Dvd drive is bad, it is not getting the data to burn, the laser that does the writing isn't writing the data to the disc. and option B is also depending on what program you are using to burn the dvd's and cd and following the correct steps. If all is good and you followed the right steps to it, then you need to replace your dvd/cd drive,
Jan 29, 2011 | Gateway (5500652) (  5500652)...
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
There is a disk in the drive but it keeps asking me to insert a disk when i try to play it
I cant understand what device (laptop/desktop)you are using.
So i will try to present, desktop or the laptop also.
Click on the link
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
And clink on RUN NOW from right side box
It will fix your problem.
It could be a problem with the lens, you shouldtry cleaning the lens, it's already gone bad there is no harm in trying. If you take a little risk can solve.Follow the instruction: Don't panic it's very simply.
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. now you can fit to your pc
  4. If it does the same problemplease change the cd/dvd rw because the lance has defected.
  5. HOW TO REPLACE CD ROM e.g. follow link=http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&dlc=&cc=us&lang=&product=242024
For Laptop http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
Hope it will help you.
Dec 28, 2010 | Gateway (5500652) (  5500652)...
I have gateway laptop Model ID58, It has DVD- Super multi Dl drive but its LED blinks every time without having any CD. Some time the drive give noise during blinking. If i put a DVD in the drive the...
The drive mechanism is going bad and needs a replacement. Rather than going through the cost of replacement, I suggest you go to Walmart Electronics section and get an Exterior USB DVD drive for about $20-30 dollars. Any easy fix.
Jan 16, 2018 | Acer (KV.16X04.007) DVD Drive
I need to replace the dvd/rw in my GT5026E but cant find the original. What will replace it
Any 5 1/4 DVD / CD drive will work. You may have to order drive rails depending on the setup of Gateways tower. You should have 2 - 5.25" Drive Bays available. The original model number and name for the DVD drive is 5648 DVD Burner Combo Drive .
The tower does have internal SATA so you can replace it with any internal SATA DVD rom you like, it doesnt have to be Gateway, and it can even be blu-ray.
Hope this helps
~mac
Nov 17, 2009 | Gateway GT5220 PC Desktop
Gateway p-6301 drivers for windows xp
Below will take you to gateway's support website. This page lists the only drivers for this laptop provided for windows XP.
P6301 drivers
Hope this helps.
Thanks,
Lolita
Sep 25, 2009 | Gateway P-6301 Notebook/ 17-inch...
Gateway p-6301 laptop, I need to replace the dvd drive, how do i go about doing it?
If the drive slides into a cavity in the laptop as most all do then this should apply. If you have the replacement drive, look at it and find a tab at it's rear with a threaded hole for a retaining screw. Locate the screw in the bottom of the laptop that corresponds with that location. Remove the screw. There should also be a small slide latch in that same area. Slide the latch to release,as you apply a pull on the finger grip on the bottom of the drive. The drive should let go with very little effort. Do not force, if it doesn't give easily, look closely for a second screw.
Jul 13, 2009 | Gateway Computers & Internet
-DVD Drive won't read or burn blank -DVD media
Just replace the drive, that unit is old and it has a bad reputation.
Mar 03, 2017 | Computers & Internet
Gateway M305CRV Notebook Logo
260 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
