Question about Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20 I just installed my Sceptre X20 and the entire screen is green. I can't figure out how to get the proper color.
Re: Sceptre X20 - Sceptre X20g-Naga III 20.1" LCD Monitor Computer Monitors
You could have a lot of dead pixels :)
Posted on Jan 15, 2008
  • 54 Answers
Reinstall your video card drivers ,
Posted on Nov 16, 2007
0 characters
3 Points
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computer Monitors
Got a sceptre x20 and when it warms on the screen goes black and i have to turn it off and then turn it on. it has this intermittence every 5 to ten seconds. Can I get some help?
More likely to have power supply problem due to bad caps, that will be the first thing to check.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: he can make you a set of caps for you.
Sep 29, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Cannot use the 5 push-bars on X7G-NagaV to reduce the pink (red in) the background. Do you have instructions for which button to push & the sequence? Thanks
Please check to make sure that the pins on both ends of the VGA cable are OK and seted properly on bothe ends.
There is no adjustment for color casting on the screen (redish, greenish, or bluish cast).
You may have problem in the monitor or the video card.
May 09, 2010 | Sceptre X7G-Naga 17" LCD Monitor
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
Sceptre LCD - no display
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Try adjusting the resolution on your monitor or the color. Make sure that the resolution is also adjusted properly in your computer system.Hope this helps and if it doesn't please let me know
Jun 29, 2008 | Acer AL1912 19" LCD Monitor
Flashing green power indicator lamp.
Check out the data plug- you may have bent some pins.
May 31, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
490 people viewed this question
Top Sceptre Computer Monitors Experts
Robert Veldman
Robert Veldman
Mike McWhinney
Are you a Sceptre Computer Monitor Expert? Answer questions, earn points and help others
