Question about Panasonic Televison & Video
My dvd recorder has stopped reading dvds. It
My dvd recorder has stopped reading dvds. It comes up with ''can not read dvd please check disc''
  • 158 Answers
REPLACE THE LASER
Posted on Jul 27, 2009
My Phillips Writable DVD driver is asking for a Blank DVD+RW9. I have Blank DVD+R Recordable discs.....why won't the DVD+R work? The Drive keeps requesting a blank disc.....they're all brand new.....HELP...
hello,,
you said you have p/n 280751-B21 , this is 16X DVDROM Read only -- this cannot do anything buit read DVDs.. it will not record anything, it is not capable..
if you give me the computer modsl and S/N , i iwll advise which CDRW/DVD youc an install in it (computer) to record and write CDs and DVDs
let me know
Dec 04, 2010 | HP (280751-B21) Internal DVD Drive
The dvd recorder has stopped recognising dvds that previously it would play quite happily. Is the likely cause a dirty lens or is it more likely to be something to do with the spindle? I get the "cannot...
I presume you hade cleaned the discs and the players optical lense before posting this request and also tried them on another player?
Basicaly If they do not work on other players then the discs have now failed for some reason: many budget priced discs I have come across only work for a few years.
If you have a 'spindle problem' then your laser is probably slowly moving off track. If so you should be able to record and then playback on a GOOD disc for a while.
May 27, 2010 | Panasonic DMR-E50 DVD Recorder
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
Cannot play all dvds on recorder would like to unlock it
My DVD player is just over 12 months old and it cant read the Discs it brings up a message reading NO DISC can anyone help please.
Warren
May 07, 2009 | LG RH177 DVD Recorder/HDD Recorder
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
The phone no. is:
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 9am - 9pm (EST)
Apr 12, 2007 | Samsung DVDR120 DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
