Question about Akai Televison & Video
Don't know how to reset the bulb timer. It is
Don't know how to reset the bulb timer. It is causing the bulbs to blow out in less than 6 months
    President:
  • 788 Answers
Not knowing the model number of your set.
Try this.
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
I hope that this helps.
Posted on Jul 13, 2009
Mitsubishi projection tv keeps blowing bulbs! Every 6-12. Months. What is causing this tv to blow bulb?
bulbs normally fail from, overheat, loose in fitting or over voltage
if it is a screw in bulb then the problem may be from a loose earth (ground ) connection in the holder ( arcs just like a welder and that cause over voltage and surges to the bulb)
if it is a ceramic holder there should be a brass strip that rubs on the thread of the bulb as you screw it in
remove the power cord from the wall socket and bend the strip out to increase the load on the thread
screw in the bulb and every so often make sure that the bulb is tight
always make sure that the cooling fan (if there is one ) for the bulb is running at full rpms before ,during and after the unit switches on/off
Sep 11, 2015 | Mitsubishi Televison & Video
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
Ford ka main beam headlights blow every few months
Are you driving along rough roads with lights on? That can shorten the life of the bulbs. When the bulbs were installed were they touched on the glass part. If so that will cause them to burn out. Wipe all finger prints before installing.
Maybe you already know all the above, if so I think maybe your alternator or voltage regulator might be set to a voltage too high for the bulbs.
Hope this helps.
Mar 30, 2014 | 2001 Ford Ka
2006 Trailblazer low beam headlights out high beams work.
Bulbs are like people - some last a long time, some croak early.
Meanwhile the part they plug into can be cleaned out and restored if metal is still there.
Aug 22, 2017 | 2006 Chevrolet Trailblazer Ext
Malibu transformer 120w 1-8100-9120-01 transformer has no power and LCD is dark. Power plug was verified to be working. Unit is new, installed, configured and came back to see if lights came on during...
I don't have repair for defect timer, except return to Home Depot and exchange for another.
Try unplugging timer to see if will reset. There is no specific reset button on timer.
Test outlet with circuit analyzer to confirm there are no electrical problems.
The label shows advisories: Don't use extension cord, unplug unit when working on bulbs, and plug unit into GFCI protected outlet to protect from surge and short.
Other advisories not shown: Unplug power pack if breaker trips or if power goes out. Wait until power is on before plugging back in. First bulb should be 10 feet from unit. Do not wrap extra cord around power pack. Match bulb wattage and power pack wattage: 200 watt power pack should have 200 watts and not more or less. Replace bulbs as soon as they burn out.
These advisories should not affect initial operation of timer, but are things that shorten life of power packs,
Open following links for resources:
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Aug 28, 2011 | Intermatic Malibu 300W Power Pack...
The unit is programmed to come on at 5:00 p.m. and go off at 11:30 p.m. It was wooking but now the lights won't come on.
Three things can cause lights not to come on:
1) Timer has gone bad.
Try resetting and reprogramming timer. Make sure you have correct mode.
I test timers. 4-6% arrive defective and most quit within a year or two.
Some go bad within a month.
If display does not show, then check battery.
Most timers have internal rechargeable battery that is not replaceable.
When rechargeable battery goes dead, timer is bad.
2) Light bulb burned out or lamp turned OFF.
3) Receptacle has no power. Plug lamp in directly and see if bulb comes on.
To see manual:
Check following link
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Dec 21, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Headlights blow out
Take it back to dealer and get them to test for over charging, how often to you have lights on,
mine last about 6 months on a volvo
but I am taxi driver
Mar 25, 2009 | 2005 Kia Sedona
My Toshiba 65HM167 orignal bulb went out after 19 months of use.The inside of the bulb exploded.I replaced with an aftermarket bulb.The tv came on for about 10 minutes and the new bulb also exploded on the...
I have the same problem. This is the second bulb in 6 months. The first one lasted 13 months. The bulb explodes inside and makes a loud snap noise, like an arc. The repair guy said it was the ballast along with the bulb. Good luck
Mar 21, 2009 | Toshiba 65HM167 65" Projection Television
Lights under the microwave won't turn off
The problem is in the control board of the microwave. We repair these circuit boards nationwide for this problem for only $32.50. For more information you can do a search on Yahoo.com (not Google) for: microwave circuit repair It's a good idea to also send a copy of the technical note sheet from inside the oven when you send the assembly in for repair. This problem is caused when the bulbs are disconnected (or blow apart from) the sockets while the power is on. Power should always be disconnected before replacing bulbs, but sometimes they just fail on their own and short, causing them to "blow" like yours did. Also, be sure to avoid cheap bulbs, as we feel they have less chance of shorting and may hold up better.
Dec 02, 2006 | Frigidaire FMV145K Microwave Oven
Televison & Video Logo
60 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
