Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Wires fried on my switch KT150-02. Got a new switch, anyone know how to hook it up? It's a Motorguide T52. thanks
If you still need to hook up this switch email me at pphhiill41@hotmail.com
Posted on Aug 04, 2009
    Sergeant:
  • 384 Answers
Take one wire off at a time and attach to similar contact on new switch.
Posted on Jul 15, 2009
I received a new on/off switch for my Ryobi BT3100 table saw. Does anyone know the wire config to hook it up? There's 2 white and 2 black wires. Thanks.
The white wires go on one side of the switch and the black wires go on the other side of the switch.
Keith (at) BT3000.com
Jun 01, 2011 | Garden
Only have 5th gear on my trolling motor its a 5 peed but 1 thru 4 do not work already replaced the switch
I have the exact same problem gears 1 through 4 don't work but 5th gear works fine, any help from anybody would be greatly appreciated. There are 4 red wires going into the switch also a yellow and a blue. The 4 red wires all have power going through them in 5th gear but when I switch to the other gears only the two middle wires have power.
Aug 14, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide model ht24 looking for wiring diagram to rewire switch
If the insulation is burnt off the main wiring you have a severe short. DO NOT TRY TO USE. Unless your a qualified electrician or motor repair tech, take it to one to have it repaired or by a new one.
Jun 11, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
Have a 56lbs thrust motorguide that is 12/24 volt. it has three wires how do i hook it up to have 24 volt
2 of the wires are line voltage and they share a common nuetral.if they hook to batteries then the common will go to the neg of each battery and the other leads go to the positive terminal
Dec 07, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Jun 13, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
848 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
