Kitchen Ranges Logo
Tom Crawford Posted on Sep 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my Wolf oven apparently getting no power? Stove top lights but oven won't light and no power to panel.
Circuit breaker is on, but the unit show no power. Could it be a circuit breaker inside the oven?
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Oct 03, 2015
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567524
Points
3788
Not sure about your make , but if 1 half of the unit works ( The top elements in your case) and the oven doesnt, I would suggest that there may be 2 fuses in your meter box ( If the oven is wired across 2 phases) or there may be 2 fuses in the back of the oven and the fuse that protects the oven has failed. If unsure, be safe and get an Electrician or a stove technician to sort it out for you.
5 Related Answers
Anonymous
  • 725 Answers
  • Posted on Sep 05, 2007
SOURCE: beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Anonymous
  • 213 Answers
  • Posted on Nov 21, 2007
SOURCE: the touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Anonymous
  • 833 Answers
  • Posted on Dec 03, 2007
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Anonymous
  • 1314 Answers
  • Posted on Jan 24, 2008
SOURCE: oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Anonymous
  • 81 Answers
  • Posted on May 07, 2009
SOURCE: Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
1helpful
I have kenmore c880 model stove , both oven and stove are not heating up after shifting to new house...any tips to get it resolved? Only oven light is working.
Make sure there is 220 volts at the wall socket where you plug the oven into. A faulty circuit breaker in the power panel on your house will only let 110 volts get to the oven so the lights and timers will work but not the heating elements.
Why doesn't my stove top and oven heat up
Check your circuit breakers in the power panel for a bad breaker. The breaker has a pin connecting both handles One breaker can trip without tripping the other. This condition will only allow 115 volts to operate the controls and light bulbs but will not power the heating elements.
1helpful
Kenmore model 970-506021 no power to burners or oven but display works
Did you reset the house circuit breaker to the oven. If the stove is only getting 120 volts instead of 240 the display will light but no heat. A remote possiblity could be a burned wire at the power connector where the main powewr comes in to the stove of a bad comnnection in the junction box.
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
1helpful
2answers
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 • Ovens
Stove lights
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Wolf Range Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
