Question about Freezers
Ice Cream Dipping cabinet running but not working?!
We currently have the Deluxe Ice Cream Dipping cabinet DD-46. One of our machines is having a problem. We've had local electricians and local refrigerator experts come to look at it and possibly fix it. However no one has been able to solve it.
The problem is that the machine is constantly on and doesn't cycle (meaning it doesn't shut off and then turn on like it normally does). The temperature, with a thermometer, reads around 20 F. The thermometer is elevated about 10 inches above the raised bottom (not the complete bottom where reserved ice cream goes). We were able to freeze a cup of water on the top of the metal grills inside (when grills are placed). However after putting ice cream tubs in (four only so we can test it), the ice cream containers were completely soft (too soft to sell) while the thermometer read 20-22 F. There is some yellow stains under the bottom of the unit. I assume is the leaking coolant.
Do you know what the problem could be? And do you know any other refrigerator experts that are in the Mackinac City, MI area?
  • 122 Answers
Ice cream needs to be below 0 degrees. It sounds like you have a refrigeration problem. The unit runs constantly because the temperature control is never satisfied. ;)
Posted on Sep 23, 2009
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Bed room door locked
Take a credit card and slide it around the door latch. Slightly pull on the door as your are doing this and it should release itself. Gently push the card and work it into the latch at a slight angle. Let me know if this works.
Feb 18, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Freezers Logo
95 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
