Double vision I have a jvc 48wp30 and it is blurly and double on one side.
  • 8,617 Answers
You need the convergence repair kit which contains the replacement parts and the detailed instructions on how to do the repair. The JVC AV48WP30 -AV65WP30 convergence repair kit is available at the following link under the JVC repair kit category. The Instructional CDs are very detailed so its a easy repair.
http://www.tvrepairworld.com/
Posted on Jul 13, 2009
Color merging wrong and double vision
See attached photos of parts in your set---see also typical photos of convergence problems.
Total parts cost under 25 dollars on EBAY and board with parts involved is easy to get out.
If this information helped out, rate this solution as very helpful. If you need to know how and what to do to repair the set I can tell you.
SD TECH
348c518.jpgVIEW OF BOARD IN YOUR SET, REMOVED; note the two black chips on left side---STK-392-110 IS THE PART NUMBER.
Aug 30, 2010 | JVC AV-48WP30 48" Rear Projection...
Picture is blurred and doubled
Convergence ICS is dead.Know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.To repair it ur self.The shop will cost u $300 dollars for parts and labors.
Jan 24, 2010 | JVC AV-48WP30 48" Rear Projection...
Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
I have double blurry vision with green and purple/red splashes on all inputs (ghostlike)
This is a very common problem. If you want to fix this yourself you will need to be able to solder, but other than that its a very easy fix. Both the convergence output ic's need to be replaced (PN STK392-110). If you have a repairman do this for you it will run $300-$500 to repair. Let me know if you want to fix this yourself and i will assist you further.
Thanks
Tim Nolan
Sep 24, 2008 | JVC AV-48WP30 48" Rear Projection...
Double vision
The double vision is from bad convergance ic's and posibly some support resistors or pico fuses. if you are not an electronics tech I suggest to have one do it. the ICs can range from $45.00 to $60.00 each and is suggested to replace both of them. some mitsies had one IC which I cant remember how much it was. tech charges vary. some prices may be $150.00 to $300.00 shop around.
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Double vision
In this particular unit what you're describing is a failure of the convergence amps. This unit takes two STK392-110 Sanyo built Ic's and one or more 2.2 ohm/1w resistors for the yoke return. replace these and you should restore normal function after a little convergence touch-up.
It's not an expensive job in a qualified shop either. If any of this sounds a bit complicated take it in and have the job done.
Have a great day!
Bill
Dec 07, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
